Paula deen pressure cooker. Can I use it for slow cooking? What is temp of keep warm? Could put lid on loose. Also, timing notches are mixed into keep warm button. I overcooked my first batch
A pressure cooker is NOT anything close to a slow cooker. The cooking philosophy are practically totally opposites. A pressure cooker basically cooks your food in a fraction of time because it is under pressure. A slow cooker takes hours.
The whole idea of using a pressure cooker is that it is sealed and applies pressure to cook the food faster. The lid needs to be sealed for the pressure cooker to operate properly. It is frequently referred to as "infusion" cooking now days.
You need to read the instruction book that came with the pressure cooker. Pressure cookers usually cook for less than an hour--my homemade pressure cooker spaghetti sauce is cooked in less than 30 minutes. They are nice and were very popular long before anyone thought of microwaves and slow cookers. However, there are some precautions to be taken. There must be water or liquid in a pressure cooker. The rubber seal needs to be cleaned frequently and, when the rubber seal warps/stretches and no longer seals, it needs to be replaced. There are also certain foods that CANNOT be cooked in a pressure cooker like rice, dry beans, etc. The pressure control valve operates to regulate the amount of pressure and releases extra pressure otherwise the unit would blow up (very dangerous!). Most pressure cookers (required on all new ones) have a small rubber emergency stopper that will "blow off" in case the pressure is too high. I've seen this happen and my mother cleaning potatoes & meat from the ceiling!
