Apple iPod nano Logo
Posted on Jan 25, 2018
LOCK SYMBOL ON SCREEN WONT COME OFF...
A little water fell on it and nothing happened, it seemed fine, but when I plugged it in to the speakers the screen went white and then it went back to normal but with the lock symbol on it and nothing works. The screen lights up and I restored it in ITunes but it still is locked. Any suggestions?
  • Terry
    Terry Feb 12, 2018
    Have you tried to double tap the home button, swipe to the right and then tap the lock icon again when it appears?
5 Related Answers
Anonymous
  • Posted on Nov 16, 2007
SOURCE: Frozen screen, nano 2 gb
press and hold both the menu and select (middle) buttons for around 10 sec until the apple logo appears... similar to ctrl-alt-del
Ekse
  • 13435 Answers
  • Posted on Jul 28, 2008
SOURCE: black and white screen and not recognized.
try this page
http://www.fixya.com/support/r561901-ipod_problems_start_5_solutions
note in the end of my post there is the online service assistant where you can check your warranty and setup repairs with apple if required.
Anonymous
  • Posted on Nov 23, 2008
SOURCE: ipod has a lock symbol and screen appears to be frozen
Nano ipod has pass code that I don't rember how do I override this to open the nano?
Anonymous
  • 4 Answers
  • Posted on Mar 02, 2009
SOURCE: IPOD NANO 8MG HAS LOCK ON SCREEN
to unlock plug it into original computer...if thats not enough open itunes.
If it is still asking for code and you can't remember it try this:(I got this from John on here and it worked for me)- with ipod still plugged in...
Go to My computer- click on tools - folder options - then the VIEW tab - tick the box for 'show hidden files and folders' - click OK -
now click on ipod (in my computer) a light file called Ipod control double click- then Device double click - then _locked file right click and delete - disconnect ipod from computer.
this should have taken the code screen away and you're at main menu. you can reset your code.... but sometimes you need to re-boot your ipod.
You can do that by flicking the hold switch over and back...then holding in the middle button and menu together until the Apple logo appears and release.
NONE OF THESE ACTIONS ERASE YOUR STORED INFO.
Anonymous
  • Posted on Jun 21, 2009
SOURCE: itouch screen is white then, when restored goes black.
make sure u hold down home and sleep buttom for more than 11 seconds. After the allple logo shows up, press the home button...i had similiar problems as some of u, and this unfroze/ fixed my issue. Hopefully, it will work for u
Rca mp3 fell into water.
Put it in a zip-lock bag filled with uncooked rice for a few days. The rice will absorb moisture.
My speakers will turn on but nothing is coming out of them. both of them are plugged in and i have unplugged them and plugged them back in. i was going to reinstall the software for the speakers but i cant...
try installing the sound card driver for your computer and setting up your speakers as default under playback options when you right click on the speaker icon
Cannot connect to xbox live, tells you to select test connection to trouble shoot? we have done that but nothing happens! also says try to recover your profile, but it isn't lost? why wont it connect to...
Try restarting your modem. Just flick the switch off for 5 seconds and turn it back on. I had the same problem over the summer, this seemed to work the best.
Jan 18, 2011 • Toys
Epson P5000 won't switch one
its software have been frozen or crupted connect it to pc and upload a software
Mmy ipod is at the music screen where it shows the
that happened to mine once i think i just let it charge...but u have to unlock it
1helpful
W350a flap came disconnected
When you take off the flap on the left little circle thing in it there should be a magnet, you should see if that fell out or not, because that's what makes it lock and go back to the music. This should help.
4helpful
My dell axim x51v is frozen where says"tap the screen to set up...", nothing happen when tap screen , seems to be in locked position.  Problem started suddenly, after it was charging on craddle ,...
On the left side of the pda is a little slide button with a lock symbol on it, make sure it is slid down. This button is a key/screen lock to ensure you dont push any buttons accidentally.
Dvd movies
Maybe you had the same problem as I did... the unit may have been dropped or mishandled during shipping or maybe during installation. If it is still under warranty, return it. If not, try this:
I took mine to a technician that went through the settings, found nothing wrong, except for the fact that it won't play video. What he did afterward was open the unit up and checked out inside. Apparently there was just some little plug that got loose and/or fell off inside. This probably happened during shipping or could have happened if someone dropped the unit I guess. Anyway he re-plugged the little plug inside and it worked fine. I'm still to pick it up and test it myself but this is what I was told today so just thought I'd share it with you guys. Maybe that's what you need to get done.
Please note that if your unit is under warranty (like mine WAS), this would pretty much void it.
3answers
Humdifier wont work
I'm having the same issue
Top Apple Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
