Exercise & Fitness Logo
Sara Rodgers Posted on Mar 30, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a nordictrack a2350. The belt runs fine until you step on it. How do I fix this?
helix44
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 132 Answers
  • Posted on May 12, 2016
helix44
Expert
Level 2:
New Friend:
Cheetah:
Answers
132
Questions
0
Helped
76725
Points
151
The walking belt may be loose. adjustment screws are at the back of the walking belt. one on either side
5 Related Answers
Anonymous
  • 79 Answers
  • Posted on Sep 10, 2010
SOURCE: Does anyone know how to remove the plastic foot
you must remove the screws allens including those found beneath the label. be careful when lifting
2manyhobbies
Ross Metcalfe
  • 135 Answers
  • Posted on Dec 30, 2010
SOURCE: I have a NordicTrack c2200. I find that the tread
There are a couple possibilities.
Remove the motor cover and run the machine.
Check the tension of the motor belt. It may need to be tightened. 2manyhobbies.jpg
Check that the pulley has not broken free from the front roller by stopping the walking belt when the machine is running. If the belt stops, but the motor and pulley keep turning, the pulley has broken free from the front roller.
If this is the case, with a drill and small drill bit, drill a hole through the pulley and roller on the inside edge of the pulley, between the ribs (not where the motor belt travels) and put a screw through the plastic into the metal roller.
Otherwise, change the roller.
Good Luck.
ercupa190
ernesto cuadra
  • 12223 Answers
  • Posted on Jun 20, 2012
SOURCE: NordicTrack treadmill squeaks when walking but fine when running.
1) lube the deck belt, and possible the deck is worn must be replace
2) lube the rollers bearing too.
3) test the bearing motor, need replace too.
God bless you
ercupa190
ernesto cuadra
  • 12223 Answers
  • Posted on Jul 23, 2012
SOURCE: I have a NordicTrack A2350 which is slipping. Some material has come off the front roller. Now when the belt is tighened and you step on the belt the belt stops but the front roller gets on going. C
see the video attached: God bless you
ercupa190
ernesto cuadra
  • 12223 Answers
  • Posted on Sep 18, 2012
SOURCE: When I run on my Nordic Track A2350, the belt slips slightly forward with each step giving me the feeling of slipping. The belt can be rolled forward when off. How can I fix this?
see the video and proceed according, use the common sense.
God bless you
Keeps stopping. I turn off power and restart but it stops again after a few seconds. How can I reset it to quit stopping after a few seconds.
Hope the speed sensor have some problem may dust on it or the treadmill need lubrication. Most of the treadmill stop after some kilometres reading indicating that its time to lubricate it. After lubrication you have to reset the counter.
check the link bellow using the search tab find out details of NORDICTRACK A2350. and follow those instruction.
www.electro-medical.blogspot.com
Belt stops while using nordic track c2255
this happen to due the lack of maintenance according the schedule manintenance. see the video and proceed.However if after you did, the problem remain,is TIME to replace the old board deck. God bless you
1helpful
My a2350 treadmill just stopped working - console and motor stopped
plealse LUBE the deck belt + rollers bearing too . you must do it after 150 miles aprox.
2) adjust the REED switch see the diagram, clean it, test for open or faulty. Tight the connector very well.
Treadmill belt stops abruptly
This happen because the lack of LUBE in the machine according with the instruction maintenance.
Please see the video and proceed according , LUBE the rollers bearing too.
God bless you
Nordik track A2350 can't fit through door
see the video and proceed according.
God bless you
2answers
Belt moves for split second then stops
1= Not rexactly, however you must LUBE the deck belt, this a problem because of lack of maintenance, probably a deck worn, this cause enough friction shut down the machine for protection electronic.
2)LUBE the rollers bearing.3)test the input voltage motor, if there are the motor need repair.4) measure the output voltage board, if there are NOT voltage, the board is faulty, see my personal TIPS, and see the block diagram. RUN the software calibration for diagnose, and troubleshooting.
God bless you
We have a Nordictack A2350 treadmill and it has a load ticking noise in the motor ? The motor runs fine but the noise is getting louder ?
as I said earlier when an engine is noisy, the problem is in the bearings and other times they seem to be the motor bearings when they are actually front roller bearings. check that and if necessary should be changed
How do I turn it on? A2350
Make sure the power is plugged in then insert the red safety key into the front. If you are not receiveing power after that then check that it is a dedicated outlet, that is not a gfci outlet, and that the breaker is not flipped.
Top NordicTrack Exercise & Fitness Experts
NOEL
NOEL
john h
ADMIN Andrew
ADMIN Andrew
Are you a NordicTrack Exercise and Fitnes Expert? Answer questions, earn points and help others
