Re: How do i fix when i hook up hdmi cord and the screen...
You must have to make setting in your ps3 and Display device. Set the display device at auto option for input source. It may be set at VGA. that why you get output of VGA but it does not display output from ps3
Did you hook it with HDMI or analog? My plasma was on the fritz but when i hooked it up analog it worked..ugly though compared to 1080P. Try a different HDMI cord as well
You will need to turn on the PS3 and hook it up with rca so you can access the console menus. Turn it on and get to the main dashboard.
1. Go to Settings -> Display Settings (not video)
2. Select [ Video Output Settings ]
3. Select HDMI
4. Select Resolution
5. Select Screen Size
6. Save the settings
7. Reboot the console.
This should resolve the problem. We've seen PS3 consoles that would not reset by performing a hard reset. We were able to resolve this issue through the settings menu though.
Let me know if it is still giving you issues.Hank
GATpro Repairs
Make sure everything is pluged in correctly and the Playstation 3 is on stand-by. The using the power button on the console hold it for about 5 seconds till you hear two beeps. And this will reset the display settings.
Press the INPUT button on the remote or TV control panel until you find HDMI.
When you turn on the PS3 keep your finger on the power pad until an HDMI message apears on the screen.
This should FixYa.
Let me know and please rate this solution.
Lone99star
When you hooked up the HDMI did you go into display settings and change all the PS3 settings to HDMI instead of AVI? I thought my HDMI wasnt working, just a blank screen but I could hear the sound, then it hit me..... change the video and display settings to HDMI and poof, there was the pic. lol
this is a very simple fix leave cords in your sony with ps3 on standby hold the power button on ps3 itself down for 10sec your ps3 will switch back to av cables
The Toshiba 32AV500U cannot display 1080p. Hook up your PS3 to your computer monitor, provided that it can display 1080p, or some other TV that can, then change your Video Output settings under Settings> Display Settings and uncheck 1080p, which will allow the PS3 to display in 1080i. Once you do that, then hook up the Toshiba via HDMI and it will work with no problem.
