Try this link for instructions on winding a bobbin
Winding Bobbin
http://www.ehow.com/how_7373026_use-singer-self_winding-bobbin.html
Winding Singer Sewing Machine Bobbin
SOURCE: Bobbin won't wind
I have checked the gears underneath and see no missing teeth for the bobbin part. The bobbin "seat" does raise, but does not engage. Thanks
SOURCE: Instruction Manual for Singer Concerto 3 sewing machine
i have this machine and would be glad to answer any questions for you
susan
SOURCE: Singer Concerto sewing machine model 9217
i was having the same problem. try putting in a new slide plate - the pressure from it holds the bobbin down, but it wears thin after a while. fixed mine.
SOURCE: Bobbin is not winding correctly
slide plate may be worn - i had the same problem. try holding down the center of the bobbin with a pin while slide plate is in the winding position.
SOURCE: Singer 6267 self winding bobbin winds around shaft under
I just figured out why my bobbine was winding on shaft instead of on the bobbin. first of all make sure the bobbin is setting up high enough, top of bobbin needs to be a fraction higher then the bobbin shuttle, next check to make sure there are no burrs on the bobbin, then make sure that the thear is catching in the groove (**** in top) of the bobbin. In order to get mine to wind i had to lett the tread go down and then slip the thread in the groove. also remember to leave the pressure foot up do not put it down. let me know if this helps.
