SOURCE: kenmore Washine Machine does not drain
sounds like a bad lid switch, agitates but doenst advance to rinse, remains full of water?? if so lift the lid up and downa few times hear a "clicking" noise??machine doesnt think lid is closed so for safety reasnos wont spin/drain replace the door latch
SOURCE: Washine Machine not draining
Check the following to combat this issue.
Check to see if there's something stuck inside the pump or the drain
hose connected to the pump (pump is usually located at the bottom
and towards the back of the washing machine).
If the drain line isn't clogged, you may have a problem with the
water pump such as a frozen pulley or a broken impeller. If that's
the case replace the water pump. Note: if you have a belt driven
washer, check the belt(s) for cracks, as this would be a perfect
time to replace the belt(s) if needed.
SOURCE: i have a haier 7kg
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
SOURCE: Please provide me with detailed
Sorry but your operation manual, which is supplied with the washer by the manufacturer, is all that is available. Members of this FixYa washing machine forum are totally independant and do not represent any particular manufacturer. We are just ordinary people from all over the world, probably working from home. Maybe a neighbor may be able to help you understand its workings?
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
