Check it speaker first. If found OK, check and replace damaged component/s at its amplifier section circuit.http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by its
left side bar, or view it in Timeslide option.
From experience: I found that rtl20.bpl is eralted to Advanced System Care ver. 6.00. an IObit program. I had to delete all IObit programs manually and stop some active process. Dida clean reinstall of Advanced System Care, and everything was fine. Hope this helps.! IObit just came out with ASC ver 6.00 a few days ago.
If you got rtl100.bpl error then there are chances that your computer has registry problems. To repair rtl100.bpl error you need to follow the steps below:
Step 1 - Choose a rtl100.bpl error repair tool,download and install rtl100.bpl error repair tool Scan for FREE.
Step 2 - Click the Scan Button.
Step 3 - then click the Fix Button and your done! It is very easy to repair rtl100.bpl error.
it sounds like a program was removed and the operating system is trying to run the program when the OS starts up. Are you having any problems with your programs or virus scanner? A virus can disable/remove files or programs. Did you un-install any programs? Did your virus scanner find any malware or virus and remove them? Try all your programs and see if any have trouble starting. Check the windows start-up folder and see what icons are in that folder.
