Good Morning friend, thank you for your inquiry!
From what you have described your Frigidaire range is displaying an "F31" error code. An "F31" stands for a shorted probe connection. This could be an issue with your RTD (Resistance Temperature Detector), EOC (Electronic Oven Control), or wiring harness. I would recommend performing a reset on your range to help clear out any false error codes. In order to reset your range you need to disconnect power from it for roughly ten minutes. If this does not help resolve your issue and you continue to receive the error code you may need to have a professional out to perform a proper diagnosis and repair. This will help you avoid any unnecessary part purchases. -Matt
Thank you for your inquiry, friend!
Based off what you have described your Frigidaire range is displaying an F31 error code and you would like to know what it means. An F31 error code means a shorted probe connection. This could be a possible problem with your sensor probe, control panel, or probe connector. I would recommend performing a reset on your range and you can do that by flipping the household circuit breaker off for at least ten minutes. If that does not correct your issue you may need to seek help from a professional technician for proper diagnosis and repair. Best of luck! -Matt
Hello Jim, thanks for your post!
From my understanding your Frigidaire range, LFGF3014LBC, is displaying an error code of "F31". The "F31" error code stands for a shorted probe connection which could be an issue with your EOC (Electronic Oven Control), wiring harness, or RTD (Resistance Temperature Detector). I would suggest performing a reset on your range to help clear out any false error codes. You can reset your range by flipping off the household circuit breaker for ten minutes. I hope this information is helpful to some degree. -Matt
Good Afternoon friend, thanks for your post!
Based off the information you have been able to provide an "F31" error code stands for a shorted probe connection. Typically this means you could have issue with the RTD (resistance temperature detector) sensor probe or the wiring harness between your control panel and probe connector. Since it could be any one of these under lying issues I would recommend a professional come out and properly repair your appliance. Hope this helps. -Matt
