The only way i know of is to take off the back casing and look at where the the charger port is and you might be able to remove it with an object a little bit bigger than the end of the charger. otherwise you cant do it your self withput messing something up on the tablet.
If I am reading you correctly the charger port from the charger has been lodged in the tablet. Get some tweezers and pull it out very very carefully. Hopefully no damage has been done. Buy a new charger afterwards.
If the end of the charger broke off inside your nabi, it will be difficult, but you can get it out. Ideally you still have the broken piece. Superglue the end, put it back in and let it set, then pull it out quickly. If you don't have the rest of the broken piece, you can use something like a toothpick or a cotton swab with the cotton tip removed. Check out YouTube for videos on this. If your charging cord just fell apart and nothing is broken inside your nabi, just buy a universal charging cord. Make sure the tip matches the one you broke. Amazon is a good place for finding these. It will still charge your device.
If an input (female receptacle) built into these devices becomes defective; only the factory service can repair them. You do not have the ability to open the case and replace the integral parts. If you did get into the case, you would not have the skills to repair the circuit board; so send it in. Generally, the company REPLACES the board or Screen, what-ever; as they too would rather Replace than FIX. Not worth the cost! to Fix.
