Number 5 cylinder is misfiring bad plug and coil are most popular the code on the video is almost the same as yours use it as a guide for yours p0300 is multiple misfire po301 is numder 1 cylinder so yours is po305
you have multiple misfire po300 and cylinder 5 po305 misfire.the misfire is causing the rough running.The computer has disabled your traction control.You either have carbon in the EGR which simulates a vacuum leak,bad spark plugs,a leaking intake manifold,or low fuel pressure from a bad pump or clogged filter.
i would start with the spark plugs and fuel filter
this indicates a miss fire on cylinder #5. can be caused by bad plug, plug wire, ignition coil, fuel injector problem either dirty or electrical, vacuum leak at the intake runner, a compression problem.
Did you resolve the other codes? p0300 random multiple misfire, p0305 misfire cyl #5, p0307 misfire cyl #7? You could have bad ignition coils or a vacuum leak. Check your coils and check for vacuum leaks at the intake manifold check vacuum hoses. Hope this helps!
These are misfire codes.This means that your vehicle is missing.The 300 is a random misfire and the 305 is for cylinder 5,and the 306 is for cylinder number 6.Check the plugs if they are good then you could have bad coils.They are top of the plugs.Hope this helps.Good luck.
might be the coil pack is bad, wires, plugs, o2 sensors, dirty injectors, catalic converter ( only if you smell rotten eggs ) . cylinders are misfireing.
