Www.ask.com/mfg.name/make/model/instruction/manual
/wiring/diagram/
/setup/instructions/
SOURCE: need wire diagram for clarion 500EQA equalizer
Your installation manual is not anywhere to be found since the product you are inquiring about was made 1985-87... however, by deduction, you can figure it out yourself...
You need a Power 12V Constant.
A 12V Switched
A Ground
And Signal Cables.
Reply with the wire colors available to you, and I will tell you what is what.
Yellow is usually constant 12V.
Red is Ususally switched 12V.
Black Is Ground.
RCAs are self explanitory.
If your EQ has HI Level outputs, the color scheme is a little more complicated.
SOURCE: Equalizer setting help
try to use the preset equalizer settings after which you can come back to the parametric equalizer and adjust to your own taste. no problem if you don't connect the subwoofer just make sure you set the hi-pass filter to off so that you will hear the full range to your speakers. but, I advice you to put a subwoofer. There is more dynamics to the lower freqs too. don't adjust the source level if there is no problem. take note the EQ of your head unit is a parametric equalizer. hope this helps while you read about parametric EQs.
SOURCE: how do I wire an car stereo to an equalizer
from what you have explain you have a no experience to do so get your system installed by an audio installer safety come first and u have no clue for your safety seek a qualified person to do it
SOURCE: wiring ID- Pyramid SE808ECHO 200watt amplifier/grapic equalizer
THE UNIT YOU ARE USE HAVE SPEAKER IN AND OUT WIRES LOOK AT THE INSTRUCTION AT THE BACK OF THE EQ AND DECIDE HOW YOU WANNA USE THE EQ
SOURCE: Hi! Looking for a manual on hooking up the speaker
Hey there ninja. I was not able to find a manual in English(Spanish only!!!), but I did find this site with a few PDFs that may help you out. It has the Features, Installation, Operation, Specifications, and Wire Connections, so it should help you out.
