Question about XO Vision XOD1735 Car DVD Player
Warning on screen when you load dvd
''warning please stop watch video player'' message on screen when you load dvd or cd.....no video image but it will play audio on dvd or cd
  • Wendy Riggenbach Mar 07, 2019
    Try going through the setup menu using your stereo remote. Scroll till you find brake detection and turn it off. Worked for me. Mine was doing exactly what yours is. I have an off brand stereo.
  • 3 Answers
The break wire needs to be grounded
Posted on Oct 03, 2009
    New Friend:
Posted on Dec 08, 2009
  • Anonymous Dec 08, 2009
    where is the brake wire what color and ground to to what wire
I have a Lada... an old Russian Car, but runs ok... i do not have a handbrake.... so i try the first solution, ground the Parking Wire (a white and green wire)
and now, the Warning message is gone... but a blue screen is showed... and i don't know what to do... i can't ear nothig but the radio... no DVD, CD, USB... nothing....
please.. someone help me!!!
Posted on Oct 17, 2011
  • 112 Answers
On the indash video there is a wire in the back that needs to be hooked up to the parking brake and you can only view movies while car is parked and the handbrake is on . unless you can find a way to bypass it i try and couldent come up eith anything good lick
Posted on Jul 10, 2009
    New Friend:
In mi dvd car i just car listen i cant watch the video and its say warning do not watch to master
Posted on Feb 23, 2010
  • karazindan Jan 27, 2011
    Can you help me also with this problem:
    "Warning do not watch to master"
    Can you help with this problem:
    New Friend:
Try going through the setup menu using the remote to your car stereo. You don't have to mess with any wires. Scroll till you find where you can turn on or off brake detection. Once this was turned off all warnings went away. I have an off brand stereo system and this worked for me. DVD wasn't playing even when parked without the big warning coming up every few seconds.
Posted on Mar 07, 2019
SOURCE:
My new radio plays every thing but when i put a dvd it says warning please stop watch vedio player . you can hear the movie but there is no picture
the parking brake wire must be connected to the parking brake system of you car. When the parking brake is engages, the LCD will be allowed to view your video. If not, the screen will produce an image saying, parking brake. this is a feature designed for the driver not to watch a video while driving. The video output on this unit will not be affected by this, el wire to connect is Pink - parking brake. this is wire connect with ground.
Oct 18, 2010 | BOSS AUDIO SYSTEMS BV9970 Car Video Player
My dvd & usb is not working. Everytime i put a dvd in or try and use the usb a blue screen appears and says WARNING PLEASE STOP WATCH VIDEO PLAYER.
Oct 10, 2010 | BOSS AUDIO SYSTEMS BV9976 Car Video Player
I just installed the unit, reset it twice, and the DVD screen is not working, and is saying "WARNING: Please Stop Watch Video" What does that mean?
I do not know this specific unit, but it sounds like a safety device built into the unit so you cant watch the screen whilst driving.. it may be that you have ommitted a sensor wire or got a sensor wire reversed.
Re-check all your wiring and make sure that the ignition live and the battery live wires have not been reversed...
Sep 01, 2010 | BOSS AUDIO SYSTEMS BV9155B Car Video...
Hello I have just acquired a LEGACY LD58MT the audio it works very well but when putting a movie in any format the screen puts on in black with a message that WARNING PLEASE STOP VIDEO WATCH PLAYER says...
This unit was not designed to be used while the car is in motion. Your parking brake must be in the engaged position in order to view the monitor. The brake wire must be hooked up to the parking brake wire or grounded in order for this function to work properly.
May 20, 2010 | Legacy LD58MT Car DVD Player
"WARNING STOP WATCH WATCH VIDEO" and no sound
Follow the following steps to overcome this problem:
  1. Locate the "Brake" wire (usually the pink wire).
  2. Connect the "Brake" wire to a negative point, e.g. body of vehicle.
  3. Test by playing a DVD and your problems have been solved.
Sep 24, 2009 | XO Vision XOD1735 Car DVD Player
Blue Screen (NO EBRAKE Message) Ebrake code entered and worked
hook your green/white camera override wire to your parking wire that should solve your problem
Feb 20, 2009 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
TOSHIBA HDDVD PLAYER A20
I have a problem like this but mine will play regular dvd's
and just stop playing hd dvd's . exact same message
gene
mrjazz1959@gmail.com
Nov 03, 2007 | Toshiba HD-A20
Blue screen will not go away
The problem is that you're trying to bypass a safety feature. Newer video head units are smart enough to know when you've just grounded the brake switch wire so you can watch it while you're driving. Try hooking it up to your parking brake wire.
Mar 03, 2007 | Dual Bravo HRC-0703 DVD Package Mobile...
XO Vision XOD1735 Car DVD Player Logo
6,278 people viewed this question
Top XO Vision Car Audio & Video Experts
Pierre Laplante
Marvin
Marvin
Larry Tezekjian
Larry Tezekjian
Are you a XO Vision Car Audio and Video Expert? Answer questions, earn points and help others
