You must adjust the record level from the input device - i.e. mixer or soundcard. There is no input level control within Cubase. It is often the case, however that the problem lies with the backing track being too loud.
Make sure the switch is set to "mic/line" and not "guitar"
Your input level will be set by the "input L" or "input R" knob, depending on which side you are using. Start with them all the way down and then sing into the mic, turning them up until you get a signal about halfway up the bar in Cubase. That should give you plenty of headroom for clean vocals.
It may be difficult to get a good sound if you have one of those cheap mics that has a "1/4" jack instead of a 3-pin XLR jack. You might want to go to your local music/pro audio store and invest in a "condenser" microphone, which is good for vocals in the studio.
Have you clicked the little "monitor" icon (looks like a speaker) on the armed audio track so that it goes orange? Once on, you should see a signal on the VU meter (assuming the line in has a good signal etc). Once recorded, turn the monitor off again to listen to the track with all the others.
I may possibly have solved this. I didn't realise that when I log off from Cubase, the ASIO driver returns to the Multimedia ASIO driver, which seems to be the default setting.
Every time I want to record with the Zoom H4 in future I'll need to reconfigure the ASIO driver to the H4 one.
I thought once I'd set the driver, it would remain there every time Cubase booted up. Apparently not.
press F4 to open device panel. there you must be able to select inputs and out puts fromyour alesis interface.
be in stereo or mono(check your alesis specifications to know how many mono and stereo inputs it has.
then when you create a new track on the right side of the sequencer window. you must see a input and uut put routing tab
so if you whant to record voice in one track select the inputs where your mic is plug
create a new track and select the other input
so for shure it will say alesis INPUT 1
alesis INPUT 2
alesis INPUT 3
and so on depending on how many inputs your devices haves.
you say it haves 2. but
are they 2 only in stereo
or two in mono
or one mono+one moni+one mono+mono
for a total of 4 inputs in mono mode and 2 in stereo mode.
i dont know witch device you have so i cant tell.
if you have any questions let me know
https://www.steinberg.net/1069+M52087573ab0.html, If u have purchased the software,just go to this this link,register ur product. U will get the steinberg cubase customer care, just try contacting them and rectifying the problem, because this is too specific and technical.BEST OF LUCK!!!! THANK U!!!!
i have a similar setup (Cubase LE & Tascam 144) and each time i start up Cubase i have to make sure there is no digital input going to the tascam. once cubase is started up but no project loaded i plug in my spdif from my DAT machine and then open my project and all is fine. does that answer part of your question?
i have a different problem though, i'm trying to record my DAT tapes which are recorded at 32khz and cubase doesn't recognize that sample rate properly. it'll record no problem, and play them back fine, but exporting always creates mismatched sample rates in the exported file. sucks big time and i have got no idea on how to fix it either.
