I've put in details several times. so here they are again. I moved and amp was working fine prior to move. After move amp powers on but not any output. Acts as if in protection mode. I need to find a schematic for the Servo 200, to fix it. I can bypass the protection circuit, but would prefer to fix it as opposed to bypassing protection circuit. All I need is a link for the schematic for the Servo 200.
SOURCE: volume and multi channel output issue
Hi there. Are you familiar with board level repair for such products ? Your problem is most likely hardware. Either some of the final output transistors are fried, or it's a dsp problem, a regulator, a diode, a transistor in the circuit.. it could be a lot of things. But if everything was working fine and it quit someday without a change in the system's setup, it really looks like an hardware issue ! Do you have a way in the manual, that sets factory defaults, a kind of reset ? A lot of such units do have that. Try to unplug/interchange speakers as well, a shorted speaker could make the amp go nuts as well, but i wouldn't bet on it. Still, i'd check that out. Hope that helps ! cheebster.
SOURCE: amp staying in protection mode
No, this amp is not a heavy power consumer- matter of fact it takes very little power to run.Maybe you should check the fuses on the amp to see if they are what is recommended.Also check your fuse kit to your amp- your fuse might not be big enough.If neither works take it back where u got it.
SOURCE: autotek mm4000.1 locked it protect
try disconnecting the power and ground wait 30 mins then hook back up
SOURCE: Bypass Triggerrelay Sharp SM-7700H.
usually this triggered input would require a 5volt d.c.
signal to turn the unit on.
Testimonial: "thanks."
SOURCE: i am trying to find schematics for the samson 120
Here is a direct page to your needed information http://www.samsontech.com/products/productpage.cfm?prodID=1821
