Question about Razor Dirt Rocket MX350 Miniature Electric Motocross Bike
What could be the problem if my son dirt bike says its fully chaged but when he turns the throttle nothing happens
It was at his grandmothers house charged for longer than 12 hours. After he took it off the charger the light remained red
  • Razor Master
  • 3,042 Answers
Did the socket the charger was plugged into actually have 120vac in the socket?
Or are you sure the charger is actually working? Is there a short so that the battery is draining as fast or faster than the charger is providing a charge?
Posted on Mar 27, 2015
SOURCE:
MY RAZOR QUAD IS CHAREGED BUT WILL NOT RUN
I have exactly the same problem and it started right around the time the "gracious" 90-day warranty period expired.....
The battery lights had been on for days, indicating a full charge, but nothing happens when turning the throttle. Battery housing is very cumbersome to open, but I'll try to disconnect the battery next.
Jul 22, 2014 | Razor Dirt Quad Bike
Why does throttle click when turned but quad does nothing?
Sounds to me like you have a broken throttle wire. Check at carb to see if linkage moves when you move the throttle at handle bars.
Jun 05, 2014 | Razor Dirt Quad Bike
My son has a Razor 350 electric dirt bike he was driving it & it just stopped. It's fully charged green light for battery. I chked plugs & battery is good, throttle wires are disconnected how to I...
Disconnected where? If the wire came out of the throttle your hall sensor is probably mangled and you will need a new throttle. Any other damage just splice it. Did the wires come off the plastic connector at the controller?
May 24, 2014 | Cycling
Dirt bike
it could be that when u are riding the bike that u are loosing air maybe because the rim is leaking when u hit bumps. this happen to my sons bike and I solved the problem by using a inter tube.
Apr 16, 2014 | 2002 Yamaha TT-R 125
How can i test electrical compontents on the mx500 dirt bike? i bought it used. it will not run the lights on the the throttle light up that the battery is full but when i twist the throttle nothing...
If the lights on a the throttle are showing a full battery then try disconnecting the brake switches at the controller one at a time. If the bike works after disconnecting a brake switch then that switch is faulty and should be replaced.
There is some excellent information on trouble shooting and testing components here http://www.razorama.com/razor-installation-guides.html
also wiring diagrams here http://manuals.monsterscooterparts.com/recreational/Razor/Wiring/
Oct 07, 2013 | Razor MX500 Dirt Rocket
My razor mx 500 motor won't turn.
I think you are talking about an electric motor on your bike . If the motor is New you may have a bad throttle switch . You can use an ohm meter to check the throttle switch . Connect the two leads of the ohm meter to the wires of the throttle switch ( dissconected) . As you turn the throttle the ohm reading should coraspond to how much you turn it .
Jan 15, 2018 | Razor MX500 Dirt Rocket
1981 yamaha midnight special 850cc. starter button and kill switch not working but lights etc are working. no power from the start button. battery fully chaged? started after chaging the throttle cable.
If no power going to kill switch check Ignition fuse, sidestand ,clutch & neutral switches.
If all OK suspect the starter cut-out relay
Ride Safe
Bike-Doc
Sep 29, 2010 | Yamaha TRX 850 Motorcycles
Off-on switch as bright as when it was new. green light on charger indicates the battery is fully charged. turn throttls and bike barely moves..... ?????
check voltage with a multimeter set on volts before trying to trottle and then after you trottle it should close to the same voltage. If not then you need to replace battery.
Jul 07, 2010 | Razor MX350 DIRT ROCKET - BLUE
My whirlpool dreyer does not work. power turns on
It has a bad Thermister. you will need to chage it. it is right on top of the blower housing
Jan 20, 2010 | Whirlpool GEW9250 Electric Dryer
Indicator light fully charged...but barely enough power to move
i have the same exact problem on 1 of my sons MX5s..i checked all 3 batteries and all that! you left out the controller clicks when the back wheels sapose to be moving ,it's not....so worse case scenerio batt,controller,motor,(650 This time)& throttle....So theres our blue print...lets hope it's just the batteries....!
Mar 30, 2009 | Razor MX350 DIRT ROCKET - BLUE
Razor Dirt Rocket MX350 Miniature Electric Motocross Bike Logo
200 people viewed this question
Top Razor Toys Experts
Bryan Mcphee
Bryan Mcphee
Level 1 Expert
William Erickson
Are you a Razor Toy Expert? Answer questions, earn points and help others
