Samsung Galaxy Tab 10.1 Wifi - Tablet - Android 3.1 honeycomb - Gt-p7510mayxab Logo
P
Pete wild Posted on Mar 27, 2015
I tried installing Epsom from play store it just says downloading but there is no percentage bar if I try to download from google is says installed but there is no app icon and nothing in application manager
Michelle Shaffer
Level 1:
Habit-Forming:
  • Contributor 21 Answers
  • Posted on Mar 28, 2015
Michelle Shaffer
Contributor
Level 1:
Habit-Forming:
Answers
21
Questions
Helped
2893
Points
32
If your attempting to download to an android device the basics are 1st. be sureYour selecting the android app model for your device. 2ND the epson printer has compatable programming. and 3rd look for your app in downloads not in app manager. It likely remains there until you take the step to install it. Hope it helps
2 Related Answers
SupportByK
Khurram Shah
  • 10322 Answers
  • Posted on Feb 06, 2013
SOURCE: Problem with running My Horse game on Galaxy Note 10.1 GT N8000
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
VERTIGO
  • 34 Answers
  • Posted on Jan 12, 2015
SOURCE: How do I recover Google apps and play store to my Samsung galaxy tablet 2, after factory reset,
Go and search it on the Play Store and manually install it.
If it fails try searching on google for an apk of google services and install it on your device.
1helpful
3answers
Please install Google play store on this device for me?
does your device support google ---and apps --if not your device wont upload it --if unit does accept search apps for google play store and upload it
How to download kodi on my kindle fire hd
Hello, here's my guide on how to install Google Play Store on Kindle Fire tablet. Just use this guide - then use Google Play Store to Install Kodi! How to Install Google Play on Kindle Fire KFire TV News
1helpful
How can I reinstall Google play store to play games
On your phone browser, search for "Google Play apk", then download and install from a reputable site. If you have Play already, but it's not working properly, try clearing the cache.
To clear the cache :
1. Go to Settings - >Application Manager
2. Go to "All" tab, find and tap Play Store.
3. Tap "Clear Data" button.
4. Reopen Play Store, you will have to log in again.
5. Go to Settings and tap Build Version to check for updates.
NOTE : I recommend installing Google Play Games from the Play Store. Simply search for "Play Games" and install.
1helpful
5 d o I install Google Play How do I install Google Play on tablet
it depends on your tablet, if your tablet is android it has already a google play app installed in it. you can download the apk at this link.
http://www.apkmirror.com/apk/google-inc/google-play-store/google-play-store-5-1-11-apk/
How can I play Simpsons tapped out it plays on another one I have
If you are referring to being able to download it from the Play Store then you might be out of luck. Each tablet reports its specifications to the Play Store and the Play Store will only show apps that your device is deemed able to run.
In this case you could try searching for and installing an apk file which is the installation file for the game and install it manually. There is a chance that these files downloaded from the Internet could carry a virus or other malware so beware. You also need to go into Settings/System/Security and check "Unknown sources" to install an apk. That's a safety step to try to stop you from installing malware.
The other option is to try a different app store - you could go into Google Play, install Aptoide and install the game from there (may or may not work).
2answers
Cant download games from play store
please describe the issue. Is it not downloading the apps like the download bar is getting stuck or do you get an error message. Please be as descriptive as possible.
Cant download play store
How to install
The installation process is pretty simply, but there are a few options you'll have to check in your handset's menus before we begin. So here's a full step by step guide to access all that glorious Google Play content on your Android smartphone or tablet.
1- Firstly you'll need a copy of the official Google Play Store apk file to install on your device. You can download this on your PC and move it over to your handset or download it directly onto your handset, in which case it will appear in your download folder. Either way is fine.
The latest version of the Play Store is 4.4.12, which can be downloaded from here, along with any older versions.
The download listed here is cryptographically signed by Google, so it's safe to install and hasn't been tampered with or infected with malicious software. But be aware of downloading files from other less reputable sources.
2- You'll need to enable the installation of external apk files before you can install the Play Store file. This is done by checking the "unknown sources" box in your devices settings, which will allow you to install apps from unvetted sources, in other words from outside of the Play Store. This option can usually be found under settings > security, but may also appear under settings > applications on certain devices. You can always uncheck the box again after installing the Play Store.
Next you'll need to locate where the apk file is on your handset. As already stated, if you downloaded the file using your device it should appear in your download folder, which can usually be accessed from the app drawer. However, if you had to move the file on your handset from your PC via a USB cable, then you'll need to be able to navigate to wherever you put the file. The easiest way to do this is to either directly place the file in the download folder, or install a third party file explorer, such as ASTRO file manager, in order to locate the apk.
4- Once you've found the file, tap on it to get things started and a popup will appear asking you if you want to continue with the installation. If this isn't working, check that step 2 has been completed successfully.
5- Continue to click install, passing through the list of required permissions that the app requires. A loading bar will appear, once that's completed the app is installed.
All done, it's as simple as that. Now you're ready to launch the Google Play Store and begin downloading apps.
if this does not work, please reply with the exact error code
2helpful
2answers
No google play store on android tablet
There is no way to have google play unless the manufacturer installs it on the tablet, as it has to be licensed like software. If you really want to, you can look up how to root(jailbreak) your tablet and how to put the play store on it like that.
What does code 912 mean? i get this when downloading apps from apps store
There are a few reasons why you would get a 912 error when downloading apps.
  • Downloading apps directly to an SD card
  • Play Store (app store) needs to be updated
  • Bad cache
The following methods could help solve the problem
Clear Cache and Reboot
  • Go to Setting >> Go to Application Setting (In some devices application setting is named as apps).
  • Go to, All the apps > >Find the Google Play Store >> Clear Data and Cache
  • Once you have clear everything, Next you need to Force Stop the application
  • Also, try to clear Cache and data of Download Manager and Google Service Framework.
  • Now, Restart your device and try to download the app.
Unmount SD Card
  • Go to Setting >> Storage >> Scroll down and select "Unmount SD card"
  • Open Google Play Store >> Download the app again that was giving you the error message
  • After successful installation, Go back to Settings >> Storage >> tap on "mount SD card"
  • If above steps didn't work, also try removing your SD card before installing.
Move app to phone
  • Go to Settings >> Go to Apps >> Select, All the apps
  • Scroll down and select the app that was giving you the error during update
  • Select "Move to phone"
  • Open Google Play Store and update the app
  • After successful installation, you can move the app back to SD card
Top Samsung Tablets & eReaders Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
