I still have the manual for my Micronta 63-712. After all these years, suddenly, the day and month are wrong. I follow all the instructions and can't adjust them.
Service manual said to be for sale online:
http://www.vintagemanuals.com/manual/Radio+Shack/63-712
SOURCE: setting time and alarm clock for timex nature sounds clock
Hold the time set key in until the time flashes. Now let it go and use the tuning forward and back keys to set the time. I had the same problem because I continued to hold the timeSet button down while trying to adjust it. If you do, the forward/back keys have no effect.
SOURCE: operating instructions for timex t311t radio/alarm clock
You can acces a PDF file of the manual at the following site: http://timexaudio.com/media/uploads/product/files/T311IB57574_35.pdf
SOURCE: I have a Zenith ZG120M alarm clock radio. I can't set it.
Here is how I set my ZENITH ZG120M radio alarm clock.
1) PRESS AND HOLD DOWN the HOUR BUTTON and then PRESS the TIME BUTTON to set the correct hour.
2) PRESS AND HOLD DOWN the MINUTE BUTTON and then PRESS the TIME BUTTON to set the correct minute.
To Set The Wake Up Time
1) PRESS and HOLD DOWN the SNOOZE/ALARM SET BUTTON and then PRESS the HOUR BUTTON to set the desired hour.
2) Press and HOLD DOWN the SNOOZE/ALARM SET BUTTON and then PRESS the MINUTE BUTTON to set the desired minute.
There are two light indicators that light up on the left side of the LED display...the top light indicator will come
on once the time turns to PM. The bottom light indicates the alarm is set.
SOURCE: Emerson cks3528 Dual alarm clock radio smartset
You can get the manual on the link below. Please alow time to load large file.
http://www.emersonradio.com/owners/SmartSet%20Series/CKS3528_110606.pdf
Good Luck and please rate 4 thumbs up for the free answer
Testimonial: "Thanks SO MUCH!!!! I've tried every button or set of buttons to set the "wrong" time zone for correct DST just to mess up Date too. Thank you SIR!"
Travel alarm clocks can have varying
instructions, depending on the type of clock you are using. Here are
some tips for use that will apply to any alarm clock.
