Model em-100c
SOURCE: Top drawer of dishwasher has a loud pump noise while running
Look for burrs on the botom impeller of the rotor. it requires no tools to check this. Take the wash arm and filter plate off, now rotate the motor rotor's base counter-clockwise and pull it out. Inspect the greay impeller closely for any nicks or burrs. If any are present, the impeller will make a LOT of noise. If it needs to be replaced, you can find them at fisher paykel parts, here is a link to the part you will need:
http://fisherpaykelparts.net/index.php?categoryid=113&productid=9
SOURCE: pump motor makes loud noise when pump comes on
If this is a high pitched sound, then this sounds like you have bearings that are starting to go out. There is not much that you can do to prevent eventual failure.
The only other option that I see is that there is something causing friction inside the pump between the impeller and diffuser.
SOURCE: when running it makes a loud continuous loud noise
Your bearing are failing. Replacing them and the seal at a local electric motor repair shop will likely cost around $50.
SOURCE: Well-Rite WR240R makes loud noise every time water flows into it
Tank may be air bound. There is an air valve on top of tank. Take cap off and depress valve momentarily. If water comes out of valve, the bladder is torn, and new tank is needed. If no water comes out, check the pre -charge pressure of tank.
First, run water in house and take note of the on-off pressure of your pump. There should be a water pressure gauge on the water line going into the tank. Take note of the cut on pressure and cut off pressure. Most well systems typically operate at 20-40, 30-50 lbs of pressure. Next,shut off electric to pump. Drain all water from tank. Take a tire gauge and check air pressure of tank. The static or pre-charge pressure should be two lbs less than the cut-on pressure,i.e if your system operates at 30-50, then the pre-charge pressure should be at 28lbs. Adjust pressure as needed. A small air compressor is ideal to use if more pressure is needed.
