Tip & How-To about Televison & Video
How to Program Acura Remote Transmitter
Acura Remote Alarm / Central locking
Model: CL Year: 2001-2003
Model: TL Year: 1998-2006
Model: MDX Year: 2001-2006
Model: RDX Year: 2007-2009
Model: RL Year: 1996-2004
Model: RSX Year: 2002-2007
Model: TSX Year:2004-2008
System Operation
  • Pressing remote transmitter LOCK button once activates alarm and central locking.
  • Pressing remote transmitter UNLOCK button once deactivates alarm (if fitted) and unlocks driver's door only.
  • Pressing remote transmitter UNLOCK button once also activates driving position memory. Driver's seat and mirrors move into memory position specified on remote transmitter when driver's door opened.
  • Pressing remote transmitter UNLOCK button twice within 5 seconds unlocks all doors.
  • Pressing remote transmitter trunk release button for 2 seconds activates trunk release.
  • Pressing remote transmitter PANIC button for more than 1 second activates panic alarm.
  • Pressing any of the remote transmitter buttons deactivates panic alarm.
  • If vehicle unlocked and doors not opened within 30 seconds, locks are reactivated.
Synchronization.
when
  • Remote transmitter battery replaced.
How
  • Press remote transmitter LOCK button or UNLOCK button 5-6 times.
  • System should now lock and unlock vehicle to indicate synchronization procedure complete.
  • Check operation of remote transmitter
Programming
How
  • Obtain all remote transmitters.
  • Switch ignition ON.
Proceed as follows:
NOTE:Point remote transmitter at central locking signal control module (located behind glove box).
  • Within 4 seconds: Press LOCK button or UNLOCK button of first remote transmitter.
  • Within 4 seconds: Switch ignition OFF.
  • Within 4 seconds: Switch ignition ON.
Repeat procedure above twice.
  • System should now lock and unlock vehicle to indicate programming mode activated.
Within 10 seconds:
  • Press LOCK button or UNLOCK button of first remote transmitter, allowing doors to lock and unlock once.
  • Press LOCK button or UNLOCK button of each remaining remote transmitter to be programmed, allowing doors to lock and unlock once as each remote transmitter is programmed.
  • Switch ignition OFF.
  • Remove key
  • Check operation of all programmed remote transmitters.
Immobilizer
System Operation
  • System arms 5 seconds after switching ignition OFF. Immobilizer warning lamp flashes during this time
  • Immobilizer warning lamp illuminates for 2-3 seconds.
  • If immobilizer warning lamp illuminates for 2-3 seconds then flashes rapidly:
  • Key code not recognized.
  • Remove key and try again.
Programming
When
  • System malfunction.
  • Key added or replaced.
How
Immobilizer can only be programmed using diagnostic equipment.
Model: MDX Year: 2007-2009
Model: TL Year: 2007-2008
System Operation
  • Pressing key LOCK button once locks the vehicle.
  • Pressing key LOCK button twice within 5 seconds activates the alarm.
  • Pressing key UNLOCK button once unlocks the driver's door only and deactivates alarm.
  • Pressing key UNLOCK button within 5 seconds unlocks all doors and tailgate.
  • Pressing key UNLOCK button within 5 seconds and holding will open windows and sunroof
NOTE: Models with "Technology Package": Alarm central locking functions can be altered using digital multifunction display in instrument panel.
  • Pressing key PANIC button for more than 2 second activates panic alarm.
  • Pressing any of the key buttons or turning ignition ON deactivates panic alarm.
  • System will automatically lock all doors when vehicle is driven above 15 mph (if function selected).
  • If vehicle is unlocked and doors or tailgate not opened within 30, 60, or 90 seconds (depending on programming), locks and alarm system are automatically reactivated.
  • Pressing tailgate release button once will open, close or reverse direction of tailgate.
Programming
When
  • Key remote transmitter added or replaced.
How
  • Obtain all keys fitted with remote transmitters.
  • Ensure doors, trunk / tailgate and hood are closed and unlocked.
NOTE: A maximum of 5 remote transmitters can be programmed.
Proceed as follows:
Repeat procedure above twice. Locks should cycle when button in pushed.
  • Within 4 seconds of each other press LOCK button or UNLOCK button of each remaining remote transmitter to be programmed, allowing doors to lock and unlock once as each remote transmitter is programmed.
  • Remove key.
  • Wait 10 seconds.
Immobilizer
System Operation
  • System arms when vehicle is locked using the remote transmitter.
  • If key code is not recognized:
  • Engine starts, then shuts off.
  • Immobilizer warning lamp flashes once, then blinks until ignition is switched OFF.
  • With ignition switched OFF, immobilizer warning lamp will flash 10 times to indicate the system has reset.
Programming
When
How
Model: RL Year: 2005-2009
Programming
When
  • Remote Transmitter added or Replaced.
  • System Malfunction.
How
Remote Transmitters can only be programmed using diagnostic equipment.
Automotive and Commercial Locksmith Acura Remote Transmitter Programming...
Televison & Video Logo
how can I deactivate my car alarm, it keeps going off everyday
alarm keeps going off - Acura Forum : Acura Forums
www.acuraworld.com > ... > CL > 1st Gen CL
Jun 6, 2011 - 8 posts - ‎4 authors
Now the alarm is suddenly going off when I put the fuse back in. ... I am going to print it and keep it with my stuff in my Acura folder. ... as i connect the battery terminals and wont turn off with the remote. can you help me on this one please? ... Join Date: Sep 2012. Posts: 2. Car 1: 1998 Acura 2.3 Cl. alarm ...
1999 TL Deactivate Alarm/pull the fuse - AcuraZine Community
acurazine.com/.../problems.../1999-tl-deactivate-alarm-pull-fuse-746888/
Oct 4, 2009 - Is there a way that I can deactivate the alarm on my car. ... It is very annoying, especially when it goes off for no reason in the .... My 2001 CL black box has 4 relays, 2 grey, 2 black.removing any and ... Troubleshooting Fail: Stuck Drivers Window, xsilverhawkx, Problems & Fixes, 5, 09-28-2015 07:51 PM. 2005 TL, HFL Malfunction and Parasitic Draw
May 7, 2012
2012 TL Remote Starter
Jul 15, 2011
99 acura tl stuck in park and brake lights won't work
Aug 25, 2010
1999 Acura 3.2TL shuts down on its own
Jul 20, 2009
More results from acurazine.com
any problems with acura 2004 ?
According to repairpal: "Honda and Acura Recall Multiple Vehicles Due to Excessive Air Bag Inflator Pressure RepairPal Expert Overview: Honda has recalled 2001-2003 Civic, 2002-2003 Civic SI, 2001-2002 Accord, 2002 CR-V, 2002 Odyssey, 2003 Pilot, 2002-2003 Acura TL, and 2003 Acura CL vehicles because the driver's side air bag inflator may produce excessive internal pressure. This could cause the inflator to rupture if the air bag deploys. Metal fragments may pass through the air bag material and cause injury to vehicle occupants. Dealers will replace the driver's side air bag inflator.
Models: Acura CL, Acura TL, Honda Accord, Honda CR-V, Honda Civic, Honda Civic Si, Honda Odyssey, Honda Pilot Body, Interior & Misc., February 26, 2010 Honda Recalls 2001-2003 Vehicles Due to Excessive Air Bag Pressure RepairPal Expert Overview: Honda has recalled 2001-2002 Civic, Civic SI, and Accord vehicles and 2002-2003 Acura TL vehicles because the driver's side air bag inflator could produce excessive internal pressure. This may cause the inflator to rupture if the air bag deploys. Metal fragments may pass through the air bag material and cause injury to vehicle occupants. Dealers will replace the driver's side air bag inflator.
Models: Acura TL, Honda Accord, Honda Civic, Honda Civic Si Body, Interior & Misc., August 31, 2009 Acura Recalls 2004-2007 TL Models Due to Power Steering Hose Leaks RepairPal Expert Overview: Acura has recalled certain 2004-2007 TL models because the power steering hose may leak onto the extremely hot catalytic converter, which may cause a fire hazard. Dealers will replace the power steering hose with a new heat-resistant design.
Models: Acura TL Suspension & Steering, April 28, 2008 Acura Recalls 2004-2005 TL Vehicles Due to Corrosion in the Wiper Motor Housing RepairPal Expert Overview: Acura has recalled 2004-2005 TL vehicles because the wiper motor may stop working. Water may enter the wiper motor breather port and cause corrosion, which may cause the electrical circuit in the wiper motor to fail. Dealers will replace corroded wiper motors and modifications will be made to prevent water from entering the existing or new wiper motor.
Models: Acura TL Body, Interior & Misc., April 28, 2008 Honda Recalls 2005-2006 Models Due to Faulty Fuel Pump Relay RepairPal Expert Overview: Honda has recalled 2005 Accord, Odyssey, Acura RL, TL, TSX, and 2006 Ridgeline models because the fuel pump relay may fail. This can prevent the fuel pump from operating, which may cause the engine to stall or not start. Dealers will replace the fuel pump relay.
Models: Acura RL, Acura TL, Acura TSX, Honda Accord, Honda Accord Hybrid, Honda Odyssey, Honda Ridgeline Engine, April 2, 2007 Honda Recalls 2006-2007 Models Due to Incorrect NHTSA Contact Information in Owner's Manual RepairPal Expert Overview: Honda has recalled 2006 Accord, Civic, CR-V, Element, Insight, Odyssey, Pilot, Ridgeline, Acura MDX, RL, RSX, TL, TSX, and 2007 Honda Fit vehicles because the contact information for the National Highway Traffic Safety Administration (NHTSA) is listed incorrectly in the owner's manual. Honda is contacting dealers and customers to provide them with a postcard containing the correct information.
Models: Acura MDX, Acura RL, Acura RSX, Acura TL, Acura TSX, Honda Accord, Honda CR-V, Honda Civic, Honda Element, Honda Fit, Honda Insight, Honda Odyssey, Honda Pilot, Honda Ridgeline Body, Interior & Misc., August 2, 2006 Acura Recalls 2006 TL Vehicles Due to Loose Front Air Bag External I"mpact Sensor Bolts RepairPal Expert Overview: Acura has recalled 2006 TL vehicles because the bolts that mount the front air bag external impact sensors may be loose. If the sensor bolts fall out, the sensor may not function properly, which may prevent air bag deployment in the event of an accident. Dealers will inspect and re-torque the front air bag external impact sensor bolts.
Acura tl 1996 alarm system not blinking
sure.
its in the manual
call acura and ask for help
or read the sections at alldata.com
or read the operators guide. lost in glove box. ?
there are aftermarket remote fob sold, with full docs./
in fact can go online and read there pages and docs,
all for free to read...... learn mode and all that.
I have an Acura MDX 2003 and can't disable the factory security alarm... I don't have a remote
If it's a cheap aftermarket alarm, check for a red wire coming off the hot side of your battery with an inline fuse. If it's not, try to locate the alarm "computer" under the driver's side dash or nearby your fuse panel. You'll find a black box with a wiring diagram glued to the side, normally strapped to a wiring harness or other fixed element. If this is the type of alarm you have, you'll need to trace each wire coming from the alarm computer and unclip each fastener that's clipped to your vehicle's factory wiring. The trouble with these types of alarms is that they can get power from a number of sources (stereo, interior lights, etc.). Good luck with this one!
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
