Hi, my hi fi system is getting on a bit now but still produces great sound quality. However I would like to be able to control the system through my phone / tablet or just any other way remotely. Does anyone know of a product / plug in that will allow me to do this with the TECHNICS SA-AX540. Thanks.
SOURCE: Technics SA-AX540 Receiver
It is unlikely that the display itself is faulty although it can happen. The typical problem is either the backlight is defective or the suply to the unit has a bad connection. If you can solder, try resoldering the pins on the display itself. The pins on the ends are the power and ground. I don't recall whether or not your model has a separate back light bulb or not. That too could be burned. Chack for that too.
Keep us posted,
Dan
SOURCE: Ipod Connection
Here's a link with a lot of discussion on how to do that.
Charlie
http://forums.ilounge.com/archive/index.php/t-37576.html
SOURCE: My Technics SA-AX540 AV Control
Heat? Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on or stay on. Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up. You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it. If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good. If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech. Check for loose speaker connections as a root cause for intermittent shutdown.
SOURCE: I am looking for a remote control for an old
It's a eur647130. Web searching turns up a bunch of them.
SOURCE: Where can I get a remote for a technics sa-ax540 receiver??
Please check this link for unversal remote that will match if you are not able to get a Technics remote:
