Coffee Makers & Espresso Machines Logo
T
Tim cochran Posted on Mar 26, 2015
I recently purchased your mill & brew 12-cup programmable coffee maker. When I program it to come on in the morning, I wake up to water on my counter and a half a pot of coffee.
It works fine if I use it as a regular coffee maker, but if I set it to start the next morning, it leaks.
1helpful
BLACK and DECKER DLX1050W 12-Cup Programmable Coffeemaker leaking water while brewing.
Question edited for full 'make model (what it is)'.
Question moved from MISC to model category.
Always difficult to find leaks. See it you can remove the bottom and look at the tank heater and element. Also look for a crack in water tank, 'clear leak', or in the basket holder, 'coffee leak'.
Contact Black and Decker and ask for a warranty replacement.
12-Cup Programmable Coffee Maker ' BLACK+DECKER
https://www.blackanddecker.com > product > dlx1050w
Get a great cup of coffee with ease, thanks to a handy range of features including Quick Touch programming, a Sneak-A-Cup feature and our optimal brewing ...
I have a Bella coffee machine I turn it on but it keep saying last Brew what does it mean
The comments on Amazon for this coffee machine suggest you should throw it away and buy a different brand name in the future.
That message has been reported on the internet to mean that it is broken for good, unfortunately, and you lost your money on it.
https://www.amazon.com/BELLA-Collection-Programmable-Coffee-14108/product-reviews/B00IJIYSXU/ref=cm_cr_getr_d_paging_btm_2?pageNumber=2&filterByStar=critical
Quoting from typical Amazon reviews above:
"1.0 out of 5 stars"Last Brew"
ByAnita W.on March 17, 2018
Color: Chrome'Verified Purchase
item lasted exactly 1 year. it is stuck on mode "last brew". it seems to be a typical problem with no fix. how ironic everybody has this same issue "last brew". not funny to wake up to that message and no coffee to boot. it did look beautiful on my counter with matching toaster."
Amazon com Customer reviews BELLA LINEA Collection 12 Cup Programmable...
7helpful
My machine doesn't brew - the water doesn't flow through: why?
i have a 12 cup programmable cuasinart coffee pot sometimes when i turn it on it will brew right away and sometimes it takes forever to brew. what could be the problem?
2helpful
Set time to start brewing in the morning
The following instructions shuld have you in hot coffee in the am.
S E T T I N G T H E C L O C K A N D D E L A Y B R E W T I M E
On programmable models CGX20/CGX23 & CGTX84/CGTX85 only
To Set the Clock:
1. Plug the power cord into a standard electrical outlet. The clock will flash on the control panel to
indicate that the time has not been set yet.
2. Press and hold the HOUR and MINUTE buttons until you
reach the current time. The PM indicator will light on the left
of the display.
The clock is now set!
NOTE: Pressing any button before setting the clock will cause
the clock to start keeping time from 12:00 a.m. You must set
the clock if you want to use the Delay Brew feature.
To Set the Delay Brew Time:
After setting the clock, simply press and hold the SET DELAY
button (Figure 1), and set the brew time by pressing the HOUR
and MINUTE buttons. The PM indicator will light up on the
clock display.
The Delay Brew Time is now set!
NOTE: To activate the DELAY BREW cycle, see the “Brewing Coffee Later” section.
To check the programmed time, push the SET DELAY button. The display will show the time you have
programmed the coffee to brew.
http://www.mrcoffee.com/Manuals/MANUALS/CGX20_43_62164399.PDF
2helpful
2answers
MR COFFEE FTX49. Brewing starts, then stops
Mine just started to do the exact same thing. So I decided to clean it using the "Clean" program and just water. I put the brewer through the cleaning program 3 times - each time it would brew water from 12 cups to 8 cups, I'd tap the brewer on the countertop, it would brew from 8 cups to 4 cups, tap it again, and it would brew the remaining cups. So, I called the Mr. Coffee help line (800-672-6333). The most-likely problem is that the hose is no longer attached in the water reservoir. The help line suggested that I take it in to a service center. I live in Urbana, IL and the closest service center is in Oak Lawn, IL - 2 hours away from me!!
Here is my solution:
1) Buy another coffee brewer.
or
2) Smash your current Mr. Coffee brewer into a million pieces (this relieves stress) and go buy another coffee brewer (probably stay away from Mr. Coffee products).
Hope this helps.
Frustrated in Urbana
Top Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sulejman Sulejmani
Sulejman Sulejmani
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
