Cycling Logo
Jack Beam Posted on Mar 25, 2015
I have a razor mx 500 Can the brake wires be disconnected and the motor still work
2 Related Answers
Anonymous
  • Posted on Dec 26, 2009
SOURCE: Early model Razor MX-500. Replaced motor, control
the back wheel won't move it try to move but it won't it's making a loud noise.every time you give it gas.what could that be...
Anonymous
  • Posted on Sep 15, 2012
SOURCE: RAZOR 500 BATTERY CHARGE MOTOR DON'T START OR EVEN CLICK DON'T WANT TO SPEND LOTS OF MONEY HOW CAN I CHECK THE MOTOR
Get a automotive battery charger that has 10 amps and hook it up to the motor. If the motor spins the motor is good. Just had to do this myself. Thought the motor was bad on ours and tested it found out it was good. Good Luck!
2answers
Razor MX 500 Electric Dirt Bike won't take a charge?
Question edited for clarity.
Question moved from Razor health and beauty category.
It is a known issue, but it may also be that you haven't depleted enough power for it to require a charge?
https://www.google.com/search?q=razor+mx500+charger+stays+green
MX 500 Razor Electric Dirt Bike has no power going to the motor.
There are some ideas here. If they don't work, contact Razor Support.
https://www.google.com/search?q=mx+500+razor+solenoid
Razor mini Cooper motor not working when turn throttle tried disconnect brake no good
The throttle goes bad on those razors. You need to wire in a pushbutton toggle switch that can accept 24v... it is cheaper than buying the throttle but, it will be full on but, it is not like the thing is that fast.
Picked this up used. Got it running by replacing all the batteries, however, when you hit the throttle the motor runs the chain in reverse. Any idea whats wrong?
I agree,the battery wires are installed/hooked up backwards. disconnect, then look at the manual for the battery installation diagram for successful installation..
Oct 16, 2015 • Motorcycles
How can i test electrical compontents on the mx500 dirt bike? i bought it used. it will not run the lights on the the throttle light up that the battery is full but when i twist the throttle nothing...
If the lights on a the throttle are showing a full battery then try disconnecting the brake switches at the controller one at a time. If the bike works after disconnecting a brake switch then that switch is faulty and should be replaced.
There is some excellent information on trouble shooting and testing components here http://www.razorama.com/razor-installation-guides.html
also wiring diagrams here http://manuals.monsterscooterparts.com/recreational/Razor/Wiring/
2answers
My razor mx 500 motor won't turn.
I think you are talking about an electric motor on your bike . If the motor is New you may have a bad throttle switch . You can use an ohm meter to check the throttle switch . Connect the two leads of the ohm meter to the wires of the throttle switch ( dissconected) . As you turn the throttle the ohm reading should coraspond to how much you turn it .
4helpful
6answers
I was given a mx350 that has been sitting in a garage for a year I charged it for 8 hours but it does nothing the light comes on to show it has power but when i turn the throttle nothing no sound or...
If it was working before it sat, then it is almost certainly the battery (these kinds of batteries suffer if sitting and not fully charged). If you had one, or could borrow a voltmeter, you could check the batt. Also, lots of car part places like NAPA can test batteries for you.
Hope that helps
2answers
Early model Razor MX-500. Replaced motor, control module to 5 wire, and throttle. Still, clicking inside controller but will not send power to motor. What's up?
3helpful
3answers
Rode mx 500 in light rain, stopped working. Batteries ok and LED
plz.we have to use a little common scense in this case.The razor-dirt rocket 500/or any model that run on _Electricity can not get "wet" for any reason.For example what happens when you drive a remote control car in water? The electrical motor dies,not before smoking first. It is nyeve of the manufacture to not a protective cover on or around the motor, which electricity flows inside. the 3 vent holes is for heat ventilation
Top Razor Cycling Experts
ADMIN Eric
ADMIN Eric
vince
ADMIN Andrew
ADMIN Andrew
Are you a Razor Cycling Expert? Answer questions, earn points and help others
