SOURCE: internet/ mms setting (PLEASE!!!!!!!!!)
Mine works fine- here are my settings on thePrada (multimedia settings for messages)
T-Mo MMS as connection
Proxy port is 9201
Proxy IP is 216.155.165.50
Internet mode is WAP
Profile name is T-Mo MMS
MMSC is http://216.155.174.84/servlets/mms
hope this helps
SOURCE: Cannot connect using LG internet cube software
how can we install the modem driver correctly please help.. confuuuuuuused
The_Wise23 - delete and try reinstalling your lg usb modem if that does not work call your provider and see if they can assist you more.
chinesebox - the best thing to do is uninstall all lg software and then reinstall it.
for all other users un-install then reinstall
SOURCE: i am unable to connect to internet via my samsung s3310 mobile
Make sure that you have the correct settings for GPRS or 3G, call your service provider and they will send you the correct settings for free.
SOURCE: wi-fi connection problem
There are 2 ways to approach your problem.
This issue may occur if you configure your Internet connection to use a proxy server that requires authentication. In some situations, the Activation Wizard can not connect through the proxy server to an internal Microsoft server and show error message.
Alternatively, this issue may occur if your firewall software is blocking the attempt to connect to the server through your Internet connection.
To resolve this issue configure the firewall software to let the Activation Wizard connect to the Microsoft server or restart the computer in Windows Safe Mode With Networking, and then try to activate the software.
(How to get there? Open settings - Network - APN/Access point - New apn).
On internet settings try this first: Usually works but not always. Under are SMARTs own settings.
Connection name: Internet
Acces point name: Internet
NOTHING ELSE
Hope it helps.
I. GPRS/WAP Internet Settings
Connection name: SMARTGPRS
Data bearer: Packet data
Access point name: smart1
User name: leave this blank
Prompt password: No
Password: leave this blank
Authentication: Normal
Homepage: http://wap.smart.com.ph
Network type IPv4
Phone IP address: 10.102.61.46
Name servers: Automatic
Proxy server address: 10.102.61.46
Proxy port number: 8080 or 9201
(differs from one handset model to another)
Default access point: SMARTGPRS
Data bearer: Choose GPRS
Access point: internet
User name: (leave it blank)
Prompt p'word: No
Password: (leave it blank)
II. MMS Settings
Connection name : SMARTMMS
Data bearer:Packet data
Access point: mms
User name: leave it blank
Prompt password: No
Password: leave it blank
Homepage : http://10.102.61.238:8002
Network type IPv4
Access point: mms
Prompt p'word: No
Homepage: http://10.102.61.238:8002
