SOURCE: PXE-E61: Media test failure, check cable
check your harddrive, is it detected in bios ?
if no, it could be motherboard or hdd, but most of the time is hdd problem, so just replace it.
if yes, your operating system is corrupt, so you can reload your operating system.
SOURCE: acer aspire 5520
necesito la tarjeta de video para mi portatil ECER por favor ke alquien me ayude :(
SOURCE: operating system not found media test failure will not reboot aspire 3680
hi..try to remove unplug or plug in the Hard Drive,, if cant work you or nothing happens you need to re-place the hard drive.about files theirs nothing ways to recover the files if the Hard Drive is totally defective..Thanks..and GOOD LUCK...^_^
SOURCE: Acer Aspire 5100-5674 won't boot. Keyboard won't
PXE errors are generated by the network boot ROM. In other words, the boot process is attempting a network boot (your BIOS' 4th boot option), which means that your system was unable to boot from a HDD, CD-ROM, or USB device (the first 3 boot options).
PXE-E61 Media Test Failure, System won't boot:
1.Go to Bios Settings
2.Remove LAN booting from booting options...For laptop ,type "X" on the LAN booting option.
3.Save The configuration
Also verify if your harddisk is detected by BIOS
Testimonial: "thank you"
SOURCE: Aspire One N214 Model #
The media failure means either the hard disk has failed and therefore cannot boot up the notebook.
Try reseating the hard drive first, so it makes proper electrical contact. If it still fails to boot up, then go to the BIOS setup and check to see if the BIOS detects the hard drive. The BIOS may have a hard disk diagnostic program, if so then run this program to check the hard disk. If the hard disk is faulty, then a new hard disk is needed and install Windows on this hard disk plus the Acer's device drivers and your programs to get a working computer again.
