Changed drum bearings and now the machine stays on the wash program. it doesnt move on to the next program which is rinse.
WASHER WILL NOT RINSE:
If your washer doesn't go through the washer rinse cycle, the most likely cause is the water valve. What happens is the water valve will stop letting cold water into the washer; therefore, once the washer gets to rinse it will either stop or not do anything during the whole rinse cycle.
This is because when you selected your water temperature, you selected warm/cold or hot/cold. The hot water came in and you didn't notice any problems. When it got to rinse, the cold water the cold water won't come in. Therefore, the washer does nothing.
To check the water valve, first cut the water off and remove the hoses off the back of the washer. Then one at a time point the hoses inside the washer tub and turn the water back on. If you don't have good water pressure, turn the water back off and remove the strainer that should be in one end of the hose. Inspect the strainer to see if it is stopped up, clean it and reinstall it. Now repeat this test. If you have good water pressure now, reinstall hose and your problem is fixed.
If you still don't have good water pressure, the problem is in your house plumbing and you need to call a plumber. If you had good water pressure the first time you performed the test, the water valve is bad and needs replacing.
TIMER
If your washer doesn't go through the washer rinse cycle the timer may be the problem. Sometimes the timer gets stuck in the middle of the cycle or won't turn at all. If the washer runs, but the timer doesn't turn, the timer is bad and needs replacing.
Do you have anti-flood hoses leading to the machine. If you do there is probably a loose tube in the back causing a small leak. When the hoses detect that water is still flowing after a certain amount of time due to the leak it shuts down and causes the machine to turn off during the rinse/spin cycle
SOURCE: I have a Bosch Classix
With the machine empty, rotate the drum by hand. if it spins freely, the belt has come off. if not, then the motor brushes should be inspected. If these prove to be ok, then the most likely cause is the motor run capacitor that would need replacement.
These three items are under $20 each.
If the problem persists after capacitor replacement, then the motor needs checking that it is not burnt out, and the last possibility is the control board. Both of these items run to $150 each.
If you do not feel competent to check these yourself, then employ a competent technician who will.
Replacement parts are available mail order quite easily.
Thanks for using Fixya! If this enables a solution to the problem, please rate accordingly Thank you.
SOURCE: Only adds water and drains
I can think of a few things to try.
1) Check for a blockage in any of the pipes or if it has one the filter
2) Brushes might be worn on the motor
3)A faulty module. The only way to check this last one is to replace with a known working one.
Good luck.
SOURCE: drum not working on bosch washing machine
I would say that the brushes want replacing in the motor, access to the motor is by removing the rear panel, remove the belt, and undo screws securing motor, remove motor, brushes are located at rear end of motor.
Please rate my solution.
Thanks
SOURCE: my Bosch classic 1200 express washing machine wont drain or spin
Possibly a blocked filter or pump.
Ths filter should be at the bottom right front of washer, sometimes behind a removeable cover at the bottom of washer.
To clean it, unscrew anti-clockwise, remove and clean.
SOURCE: Motor does not turn in wash or rinse mode. works
Hi, well NO it's not the motor and there are no diodes inside the motor, thats not actually the way they in which they are made to rotate and reverse direction.
This is done by "Driving" the motor with a pulse width modulated signal, that makes the motor spin,as the electricity is switched from pole to pole the motor's stator is attracted to that pole and moves forwards or backwards depending on the direction of the waveform.
So whenever a motor isn't working, spinning, then most often if the motor works, as it actually appears your is OK, then the "Controller' is at fault. The controller in this case is the Main Controller Board. This must be replaced in it's entirety. If you wish to DIY, then please find below a service and repair manual, to use to try and track down exactly whats wrong...
http://www.appliance411.com/service/repairmanual.shtml
http://www.scribd.com/doc/8677902/Amana-Top-Load-Washer-Service-Manual
service and repair manual above..
But you see these days, it is nearly always my professional opinion that one should always get a "Quote" from the manufacturers recommended service center,Anma in your case, please contact a local or head office and ask for a referral to an Authorised service center. I cannot stress how important that last point is. It is even worth the cost of shipping. You see an authorised service agent, will have trained staff, trained on their brand, also they have first hand access to parts, original parts. This will actually save you money and ensure you can actually get it back fixed. Of course asking for a "Quote" also gives on the option of repair or replace. Often my clients,do not go through with repair, unless it is moderate, but in some of the more costly jobs they see it, as do i, that a replacement, with a warranty, is a better option.
