I have a Springfield 1903 sn#33178 Circle p. Right side stock below carrier bolt stamp 24 5. Under fore stock a (1) looks like maybe. Then 472. Stamped low HIGH low in that order. Rear under stock two circle P,s one light one heavy stamp. Heavy stamp P. Right side of P is an (I) stamp. Then small (D) stamp blew (Parts)
SOURCE: warning light in a circle with 3 rectangular dashes vertically going down each side ofthe circle
It is the warning light for your front brake pads being worn.
SOURCE: 07' mitsu. endeavor. what is
This sounds like the low tire pressure warning light. The tires have small sensors on the back side of each valve stem that monitor your tire pressure. I live in the northeast and when the temperature really drops I get the same light. Usually once you get rolling the friction of the tire on the road heats up the air in the tire causing it to expand to it's proper pressure. You may want to check your pressures to ensure that they are inflated properly.
SOURCE: BMW 318i 1999 WARNING LIGHT
i have a 1999 323 the light that is on is a circle with 3 blocks on each side what does it mean?
SOURCE: I need a vacuum diagram for a 1990 Ranger 2.9 L
I highly doubt you'll be able to find one. I don't think even dealers hang on to those that long. If nothing is broken and out of place, I recommend going to a parts store and finding similiar material to mickeymouse back together. If the routing is messed up, then your best bet is to find one still in tact to compare with.
SOURCE: Light that looks like exclamation point in a
First off you need an owner's manual. You can get a free one here. http://pdfservicemanual.com/automotive/2001-ford-taurus-owners-manual The light that looks like a gear with an exclamation point inside indicates there is a problem with the transmission. May just be low of transmission fluid. To check the level dive the car until the transmission is warm, park on a level surface, place gear shift in park with engine running, and check transmission fluid level. Add only if necessary and do not overfill. If it is not low of fluid then seek professional help. The exclamation point in a circle under the fuel gauge next to the Brake light indicates you are low of brake fluid. Check the level of the brake fluid. If it is low you more than likely need to check your brake pads as they are worn out.
