Ovens Logo
k
keith dwarte Posted on Mar 24, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Have removed the oven door for cleaning door will not reseat
Have inserted hinges opened door but it keeps rejecting
Barry Coates
Level 3:
  • Whirlpool Master 3,463 Answers
  • Posted on Apr 02, 2015
Barry Coates
Whirlpool Master
Level 3:
Answers
3463
Questions
Helped
1406885
Points
12766
You have not got the hinges located properly, this is the only possible explanation.
5 Related Answers
Anonymous
  • Posted on Nov 15, 2008
SOURCE: How can I remove oven door so that I can replace the broken glass
I just took my oven door off and took it apart to clean the glass inside. I don't have a maytag but they probably all work alike. Just open the door like you are going to broil something and just lift it up. It should slide right off. Shouldn't have to unscrew anything. Hope this helps. Arlene
douglas smith
  • 1462 Answers
  • Posted on Nov 29, 2008
SOURCE: Neff Oven Door Removed Incorrectly
you need to lock the hinges to get the door back.
it needs some strength
lay door flat on floor
force hinge against the spring until right back and put the locking arm over. i use my feet for this!
barkencoa
Barry Coates
  • 3463 Answers
  • Posted on Feb 08, 2009
SOURCE: Baumatic 720 Double Oven - Door has come off hinge.
If you got to:
www.youtube.com
Then click on youtube videos, and in the search box type in: fitting oven door hinge, you should be able to get all the info you need to help solve your problem.
Please leave a fixya rating for my suggested solution.
Thanks.
Anonymous
  • Posted on May 05, 2009
SOURCE: Oven locked so I can't shut door/operate oven
Thanks a million, solved the problem like a charm. For those that can't find it, it is on the left side orf the OVEN, not the stove. Once you open the door, you'll find it on the frame's upper left side corner, can't miss it. Good luck
Anonymous
  • 10865 Answers
  • Posted on May 20, 2009
SOURCE: self-cleaning oven door won't open
The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
Most ranges today use 3 different types of door locks...one is a solenoid controlled lock ( you hear a loud buzz noise when setting or unlocking the lock and has a arm that you must move to set the lock )...another is a heat sensitive lock ( has a arm that you must move to lock and un-lock, makes no noises and has a spring that slowly moves to lock the door will the oven is heating up )...Some locks are motorized ( no handle to move, the motor locks the door by it's self when you set the range for self clean )... If the motorized and heat sensitive locks fails to open after the self clean cycle, you must access the lock and move it yourself to open the door. On the free standing ranges, most times you must lift the cook top to access the lock mechanism. On built in ovens, the oven must be pulled out to remove the top access panel to get at the lock mechanism. Some build in ovens can have the control console removed to access the lock system. On the heat sensitive style of lock, there are no electrical parts to operate the lock, usually you will need to replace the lock. On the motorized style of lock, you will have to use a ohm/volt meter to test why the motor will not work. On the solenoid style of lock, the solenoid is often mounted on the back of the range and can be accessed by removing the rear panel, some may be mounted at the front, such as in a built in oven. The failure of the solenoid style of lock is normally caused by a bad lock solenoid. In order to get your door open, you must operate the door latch mechanism manually. Unplug or remove power from the range. Take the rear cover off the range. Locate the door latch assembly and operate it manually and open your door. Then check continuity of the solenoid. Some of the latch assemblies have micro switches to supply power also. You may need to check them. You should be able to get the door open and use your range until you can get a tech to repair if you can not repair yourself.
If you've interrupted the clean cycle or have accidentally set the clean cycle with the oven door open, the latch may have engaged and now the door can't be closed because it will hit the latch. There may be a door activated* switch on the front face of the oven. In this case you may need to manually press that door switch with your finger while at the same time canceling the clean cycle to get the latch to retract so the door can close fully again.
My oven door won't open and its not locked or on clean. what do i do
These Videos will help with your cooker problem.
If you need more video help on appliance repairs visit our Video Tutorial Library at our website
1 how to remove your oven door for cleaning or repairs and how to reseat the door when finished.
2 How to change and fit oven door hinges.
We can not allways cover Every model but hope this helps. Remember to send us an email if you can’t find the part you need.
We also supply all the Parts you need for Repairing your cooker oven Door.
Oven Door Hinge Spare Parts
Oven Door Glass panels
Cooker Door Handels ETC
Cooker Door Catches ETC
Cooker & Oven Door Seal / Gaskets
Remember to Leave feed Back and pass our site on to your Friends:
Our Shop http://www.apart4u.co.uk
Our Video Help Section http://www.apart4u.co.uk/video-tutorials.html
Mar 03, 2010 • Ovens
3answers
Whirlpool Supercapacity 465 Oven (RF396 LXE2) Door Problem
These are the instruction on how to remove and replace the door, be sure you locate the removal pins to being able to put it back
2helpful
Removing the door from a thermador oven CT130
Usually you will find a hole in each hinge to hold the hinge open when removing the door.
It is impossible to fight the door hinge springs and remove or install the door.
One opens the door and puts a nail through the hole to keep the hinge open for each hinge.
1helpful
2answers
We are having a difficult time getting the door back on the oven. Can you give us a tip on how to keep the hinges from snapping back when we are trying to hook the himges back onto the rods?
Passing on the solution. Some other blogger helped me, so I hope this will help you. Mine is a Kenmore Gas range, but the hinges might be similar. They are fixed on the door, not on the range. Get a couple sturdy nails or similar items and keep them in your hand. Use your foot to push the hinge all the way down, as if the door were fully open. You should see a hole in the hinge, in which to insert the nail to hold the hinge open. Repeat on the other hinge. Carefully lift the door in place and set the hinges so they hook onto the latches properly. You should be able to open the door a bit to take the tension off the nails. remove the nails, and that should be it. Even if your hinges aren't the same as mine, the principle seems to apply. My problem (maybe yours) was that I couldn't open the hinges and keep them open when trying to replace the door. They just would snap closed. Very frustrating.
How to put oven door back on after removing!
Although very tight (because the oven is only 1 yr old) i managed to get the hinges into the open position, then slide the door into position on the oven and close the door. The hinges did go back and lock as they should but I struggled for almost 30 mins before success.
1helpful
I removed the range door to clean oven. Now I
NOTE: The door removal pins you inserted must still
be in both sides of the door.
1.
Grasp the door on the sides with your fingers on
the front of the door and your thumbs on the
inside surface.
2.
Rest the hinge hanger so that it is flat (at the
bottom of the hinge hanger on the bottom of the
front frame slot).
3.
Position the door with the hinge hanger slots
almost parallel to the front frame.
4.
Push up and in until the hinge hanger slots
become fastened to the range. Lower the door
and rotate it slightly from the front to the back
until the slots are fully fastened. The hinge
hanger will be close to the bottom of the front
frame slot.
5.
Pull door open about halfway and remove the
door removal pins. Save door removal pins for
future use.
6.
Close the door.
Decor double oven - Door adjustment
Unfortunately yhe door hinges are non adjustable.
The only solution is to replace the hinges as a pair.
Hope this helps.
How to remove oven door
open the door about six inches and lift with one hand on each side of the door. The door can be pulled right off the hinges which are merely rods that insert into a hole in each end of the door.
2helpful
2answers
How do you install oven door on Beaumark Model 13340-1
Figured it our by myself - the 2 hinges (long and short have to be "hooked" together and then inserted into the oven hinge opening.
After I solved it found the solution is also posted on appliance repairs- how to remove and install oven door. It also posts pictures.
http://www.applianceaid.com/oven-hinges.html
Jan 23, 2009 • Ovens
2answers
Jenn -air oven w30400p
Do you mean the service engineer replaced the hinges?
If so call him again and tell him he didn't fix it. The service engineer should come again and fix it for free if there's any justice in this world.
Top Whirlpool Ovens Experts
ZJ Limited
ZJ Limited
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
