I contacted MGA Entertainment and they are not making the replacement balls any longer.I contacted MGA Entertainment and they are not making the replacement balls any longer.
You can't post conmments that contain an email address.
The Babylock Esante ESE1 and ESE2 hoops are not compatible with the Esante ESI1 or ESI2 hoops. The Babylock ESI1/2 used the same hoops as the Brother PC7000 and PC7500. The ESE1/2 use the hoops that are compatible with the Brother PC6500 and PE700 series embroidery machines.
I wish that I had better news for you. This site has hoops for sale for both the ESI1 and the ESE1: http://www.allbrands.com/categories/871 . If you need hoops for either machine, use the compatibility data on each machine type to help you find more vendors that may have the embroidery hoops.
THIS ANSWER IS REGARDING THE HOOPS OF AN EMBROIDERY MACHINE IF THIS IS YOUR PROBLEM. THE FABRIC IS SLIPPING EVEN THOUGH YOU HAVE TIGHTENED THE CLAMPS. IF YOU WILL MAKE THE EDGES OF THE HOOPS ROUGH THE HOOPS WILL HOLD FABRIC BETTER. THIS CAN BE DONE BY TOUCHING THE EDGE OF THE HOOPS WITH A SOLDERING IRON SO THEY AREN'T QUITE AS SMOOTH. DON'T BE CRAZY ABOUT DOING THIS SO THAT YOU DON'T RUIN YOUR HOOPS. IT DOES WORK THOUGH.
Last time Arcade Hoops replacement parts I bought from amazon. Take a look on this link Amazon com Arcade Hoops replacement. I hope this was helpful. cheers
I wrote to the company and this was the response: Thank you for contacting MGA Entertainment We are sorry. The product is discontinued and replacement parts are no longer available. We can only recommend checking second hand sources such as ebay or local hobby stores. We do apologize for any inconvenience.
THE LOWER BALL JOINTS ARE A VERY TIGHT PRESS FIT INTO THE ARM, YOU NEED TO BUY A BALL JOINT PRESS KIT TO REMOVE THEM, BUT BASED ON MY PAST EXPERIENCE IT IS BEST TO JUST REMOVE THE LOWER CONTROL ARM AND HAVE A MACHINE SHOP PRESS THEM OUT AND THE NEW ONES IN, IT IS VERY EASY TO DISTORT AND RUIN THE CONTROL ARM DOING AN "ON THE CAR REPLACEMENT", THE BALL JOINT PRESS KIT RUNS ABOUT $50-$200 DEPENDING ON THE MAKER AND THE QUALITY, TRY WWW.HARBORFRIEGHT.COM TOOLS FOR AN ENTRY LEVEL KIT.
