Followed the instructions to descale with the gaggia product. bottle says half contents. Instructions say full bottle. No quantities mentioned. Descaled twice now. 3 months old and live in soft water area and only use it twice a day. the red light is still on. Trying now with max full tank. help!
Fill it up the tank with descaler and start the machine on descaling. Leave it to trow all the liquid and must finish to the bottom,leave the machine to get AIR when descaler finished.Then the machine will stop and will tell you to put fresh water to clean . Fill the water tank to the MAX level and continue with the program. When the water is on minimum ,machine will stop,and the descaling process must be finished.
Good luck
SOURCE: descaling
I had this happen once and had to put it through the descale process again. Just put more water in the tank, try it again and see what happens.
Winesnob
SOURCE: CANNOT PRIME PUMP AFTER DESCALING - therefore CANNOT MAKE COFFEE
first vinegar is not strong enought proper descaler for expresso machine and in our water container the hole in the bottom put water in the tank with a hoseor turkey juicer our anything you got push water in hole you need to pressurize to forse the pummp to trim itself hope it help fixya pierre
SOURCE: descaling
(Button 26 is the right-most one (2 intersecting
ovals.)
From the Manual:
Press the button (26) for at least 5 seconds to
select the descaling operating mode; the LED
emits a fixed light.
• Direct the steam nozzle (14) toward the drip
tray.
• Position a vessel of adequate capacity under
the steam nozzle and turn the hot water knob
anticlockwise (16). The appliance starts an
automatic descaling cycle with pauses preset
by the manufacturer and managed
automatically by the appliance.
• At the end of the cycle, the flow of the
descaling solution is shut off and the 5 buttons
start flashing simultaneously.
• Turn the knob of the hot water nozzle (16)
clockwise to OFF. In this case, also the warning
light (27) flashes.
• Rinse the water tank and fill it with fresh
drinking water.
the steam nozzle and empty 2/3 of the
contents of the water tank by turning the steam
knob (16) anticlockwise; to shut off the flow,
turn the knob (16) clockwise.
• Let the appliance heat up and empty the
remaining contents of the water tank by turning
the steam knob (16) anticlockwise; to stop the
flow, turn it clockwise.
HTH
dave
SOURCE: descaling a Saeco InCanto deluxe
Press and hold the descale button(lower right), it will light up.Then you can start the process. The machine will prompt the next step when the solution in the tank is used up. Have a go.
SOURCE: I have descaled it twice and the red light is still there
You have to press the hot water button for 10
seconds to disable the descaling
alarm.
The steam button on the left.
How long does it take for your machine to grind for 1 cup? Longer then 10 seconds? Grinder setting?
Descaling should be done every 2-3 regardless if the light comes on or not. To reset the light hold the steam button until the light goes off.
Descaling information can be found at http://www.cerinicoffee.com/clean_descale_coffee_equipment_instructions.asp
Hope this helps!
