Cleaning the hopper, removing and replacing the auger and installing a new motor and ... Most pellet stoves do not have a removable auger cover, but you can see a ... youcan hear the motor attempting to spin the auger, turn off the auger and ...
With the spark plug disconnected and the key out, try to move the auger from the front.It may be jammed (sometimes a rock). Then look behind the auger at the belts. Of course I'm guessing that you checked the shear pin that goes thru the auger and the shaft
Make sure that there electric power to the auger motor. If it's plugged into an exterior wall outlet, unplug it and plug in another electric device (like a lamp) to make sure that outlet still works. If it doesn't, go to your home's Circuit Breaker Panel and check for a tripped breaker. If you find one that's tripped, reset it and try plugging in the auger motor and turn it on. If it starts working then suddenly stops, it probably tripped the circuit breaker again. That would indicate one of three things: The cord from the auger motor may be bad; the auger motor itself may be shorting out; the circuit breaker may be failing. If it's the receptacle or the circuit breaker, I'd advise you contacting an electrician to have them check and replace it. for the Auger Motor, go to Traeger's website home page and look for Trouble Shooting or Customer Support. Better safe, than sorry.
You have a cube of ice jammed between the rings of the auger...this stops anymore ice from moving out of the auger...
remove ALL of the ice from the tray and the auger and then let it refill... then it will work again...
