SOURCE: I have a motorola bz60.
Here is how to set your default ringtone:
Main Menu
Settings
Audio
__ Detail (2nd line .. if style:loud then line 2 will say Loud:Detail .. if style:soft then line 2 will say Soft:Detail)
Now you'll see
Ring Volume:
Calls:
IM:
Messaging:
Voicemail:
Calendar Alarm:
Data Calls:
File Transfer:
Ringer IDs
Key Volume:
Reminders:
Click on Calls
Click on Music
Now you can set the default ringtone.
To set a specific ringtone for each person in your address book:
Main Menu
Address Book
Click Options
Click Edit Contact
Scroll down to Ringer ID
Music
Now you can set ringer ID for that contact.
SOURCE: doesn't show mp3 files on micro sd card
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-fareast-font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
You will be really happy to know that you can add music to
your Kyocera X-TC cell phone. First you should
have already saved MP.3 music to your music file
in your computer. From what I understand the Kyocera X-TC will only play MP3
format.
Here's what I did.
First you'll need the following items:
1 Micro SD disk
1 adapter to hold the Micro SD disk
1 card reader - You insert the adapter into the Card Reader then connect the
reader to a USB port in your computer and download the music from your computer
to the Micro SD drive. I purchased a great 12-n-1 Iogear Card Reader from
Walmart.com for under $15.00
Steps to formatting the Micro SD and downloading music to the Micro SD disk:
First: Remove the battery from your Kyocera X-TC for 30 seconds
Second: Put the battery back into the phone and PUT THE MICRO SD DISK IN
THE PHONE and turn on the phone
Third: The phone will automatically recognize the Micro SD disc and
a message will appear "Your disc is not formatted. Would you like to
format this disc" and of you would of course choose "Yes".
Fourth: After the Micro SD disc is formatted, place the Micro SD into your Micro
Adapter, then place the micro adapter in your card reader and plug the reader
into the USB port in your computer.
Five: After you plug your card reader into the USB port your
computer will open up the Micro SD disc in a drive like drive I: and you'll find that that drive has two files
a Music file and a Picture file.
Six: Then you open up the file on YOUR COMPUTER WHERE YOU SAVED MUSIC in
MP3 FORMAT
Seven: Then right click and highlight on all the MP3 songs
you want to save to your Micro SD disc and choose COPY
Eight: Then return to the drive where your Micro SD disc is and PASTE THE SONGS
TO MUSIC FILE IN THE MICRO SD DISC, and that’s it. From here you just put the
Micro SD disc into your phone and watch the songs upload. Hope this helps!
"No SD memory card inserted" messages appears when using digital cameras,
"A media card hard been inserted that contains errors. Do you wish to repair the Media Card now?"
You can read the files on SD memory card, but you cannot write new files or you cannot edit files on SD memory card,
"Access denied", when SD card is corrupted or broken,
you can fix sd memory card errors first and them format you sd card.
