If you were flooded then drain hose does not seem to be clogged. Yes severe thumping would or could cause washer to bounce around enough to pull drain hose out. Thumping would be because of unbalanced load. Or worn dampers and/or springs. Post make and model for better answers.
Testimonial: "Thanks for your quick response! You said to post the make and model for more info.It is a Kenmore Elite, with Smartwash QuietPak9, if you have further info."
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occurs. Removing and Cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there is gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Check for tips on the link below to identify parts and removal:
http://www.espares.co.uk/advice/washing-machines/a/7
