Good Morning Richard, thank you for your inquiry!
Based off the information you have provided your Frigidaire oven door is stuck closed and you are unable to shut the door. You can disconnect power from your range for at least ten minutes and that will reset your oven. This may trick your door latch into opening.
You can also hold down the cancel or clear button for 10 to 15 seconds that may allow your door latch to release. Also attempt to hold down the light and cancel buttons. I hope this information has been helpful to some degree. -Matt
is not actuallly physically closing??? perhaps the lock/ latch has partially engaged prevetning door from closing, and with the door oopen it cannot do anything for safety reasons. can you see a door /light switch thtyou can depress by hand??? if so push and hold it in the light should go out, and at this point continue to hold in switch and try starting a self clean cycle ( dont worry it wont actually start cleaning right away)it then should activet the latch assy to fully engage and suppoedly lock door, still depressing the button then press thecancel button and the latch should return to the normal resting position and you can close the door
SOURCE: Oven Lock stuck open before start of self-cleaning cycle
push in on the oven light switch and hit clean then cancel you have to hold the oven light switch thats what tells the eoc the door is closed if this dont work reply to me
SOURCE: Door locked after cancelling self clean option
Open the door. In the upper left corner, press and hold the door switch (the one that controls the inside light). Start a self clean cycle and wait for lock motor to engage. When the lock stops moving it should be in the unlocked position. Press cancel to stop the self clean.
If you need more assistance let me know.
SOURCE: Interior oven light won't shut off.
Hi, i would check the pressure switch and its connection as well. either the switch is malfunctioning or the wires and connectors are corroded. simply replacing the wires or switch will fix this issue. the switch is usually located on the rim of the inside of the oven door. it will make contact with the oven door and as the oven door closes, the pressure switch is depressed inwards, thus, opening the circuit and cutting power to the light.
Please rate and god bless:)
SOURCE: Oven locked so I can't shut door/operate oven
Thanks a million, solved the problem like a charm. For those that can't find it, it is on the left side orf the OVEN, not the stove. Once you open the door, you'll find it on the frame's upper left side corner, can't miss it. Good luck
