Error message says switch off and then back on. Icons still flashing. Printer icons on screen show a cross indicating no ink. Is there a reset?
Hi allen pettitt, I want to help you with your question, but I need more information from you.
Call Customer Service For Help & Support Call +1-888-633-7151Toll Free 24x7/ and visit our site more information https://www.epsonprintersupport247.com/epson-error-code-0xf4/
In printer setting there may be a cartridge detect tab try it.
SOURCE: Code:P error message: Pad saturated.. ink leaked..replace cartridge
Hi!!
Chances are the printer needs maintenance, you can actually send it to a repair center to replace the inkpads for your printer, try this link for information and you can download as well the utility from this site after registering:
http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp
Your printer has a one year warranty if its still within the warranty call epson if not try this site www.epson.com/loyalty and try the passcode minute or market and register. Hope this help. pls dont forget to rate solution. Thanks!!
SOURCE: restart after replace ink cartridge
my CX4800 has done the same thing. I ran the utilities dozens of times, replaced every cartridge and it feeds papers the print head moves like it's printing but nothing is imaged on the paper.
Searching the web is my last chance to fix it before i toss this 18 month old printer and never buy an epson again.
SOURCE: RX620 Error Message
This message comes up after about 40000 registers on a use counter. I posted what I did on the Epson RX620 forum. Look it up. Basically I bought a repair manual on the net for about $10.00 I used this to take the RX620 apart down to the waste ink catch pads which I removed cleaned dried and replaced. It was a long job the first time and you need the manual in order to figure out how to do it. My pads were only about 1/3 used but I live in a dry climate. So punch those override buttons and keep going. You might put a plastic sheet or pan under the printer to catch the waste ink when it actually does leak out.
SOURCE: RX620 "Ink Cartridges cannot be recognized"
Found the solution at
http://www.fixyourownprinter.com/forums/printer/54833
Try pressing down on the cartridges after inserting them and closing the top of the cartridge carriage. Worked like a champ on my R320 printer!
Cleaning the contacts on the cartridge with a soft tissue may help too.
SOURCE: I have refilled my ink cartridges on my epson c60
If you have refilled your cartridges and haven't re-set them, that's why they won't work. You have chips on both cartridges that need to be re-set every time you do a refill. You can either buy a re-setter on e-bay, or go to a refill shop to re-set them. What the re-setter does is assign a new serial number to the cartridge, thus "fooling" the printer to think you have popped in new cartridges. That is the only way to bypass the protection (chips) that Epson has put on their cartridges.
Sometimes, the message "low ink" or "no ink" appears even if the cartridges are not totally empty. If you are certain that their still is some ink int the tank, just re-set the cartridge without refilling it.
