Question about Mercedes S-class S500
My mercedes s500 v8 is stil running on 4 cylinders plugwiers,destrubtercaps,rotors is ok
    Top Expert:
  • Mercedes-Benz Master
  • 6,815 Answers
Hello
u will find a lot of wiring diagrams and circuit diagrams help books and stuff like this .. im a frequent buyer there since Im a mechanic so take help from there
Posted on Jan 29, 2019
2 Suggested Answers
SOURCE:
  • 20 Answers
SOURCE: What is wrong if my mercedes s 500 1995 v8 is running on 4 cylinders only.I have checked the spark plugs, plugwiers ,two destibutors and routers and thy seam to be allrite .The car has got two coils a
With the little information you provided, My first suggestion in s a faulty pick-up coil in one of the distributors. Because you are missing half of your cylinders, your problem is likely isolated to one of the two distributors. If the Cap/rotor are good on both, the pick up coil (or equivalent) in one of the distributors may be faulty and will cause all the plugs on it to not fire.
Posted on Mar 21, 2015
What is wrong if my mercedes s 500 1995 v8 is running on 4 cylinders only.I have checked the spark plugs, plugwiers ,two destibutors and routers and thy seam to be allrite .The car has got two coils asswel
Mar 21, 2015 | 1985 Mercedes-Benz S-Class
I have a 2000 dodge Dakota with the 5.9 v8 my ecu was not reading to my obd2 scanner so I replaced the ecu now that I have done that it sill wont start my fuel pump is priming and my spark plugs are wet I...
What about spark plugs and plug wires on those two cylinders with no spark? This is a v8 engine, you didn't mention the other cylinders? The rotor turns when you crank it?
Oct 25, 2017 | 2000 Dodge Dakota Quad Cab
Hello i have a 1993 Mercedes Benz 400sel. i have changed the distributor caps, rotors, and spark plugs/wires. it is only running on 4 cylinders right, now and i don't know why. There is no spark on all 4...
Hi Atsy,
I'd believe that the problem could be a bent distributor cam shaft (The center shaft inside the distributor.
Have it checked and if I've been a clever boy you can give me a rating
Regards Johngee10
Feb 11, 2011 | 1993 Mercedes-Benz Mercedes Benz 400 Class
Changing a coil cylinder #2 need firing order
1-3-7-2-6-5-4-8
Coil On Plug ( C.O.P. ) ignition system
The engine cylinder / spark plug locations are numbered :
firewall
4 - 8
3 - 7
2 - 6
1 - 5
front
( on your 4.6/5.0/5.8/ liter V8 engine ) ford_cyln_1234.gif
Rotor Under Cap Spins:
Counter
Clockwise
Aug 24, 2010 | 2000 Lincoln Town Car
Toyota ceilca 2000 gts will not start
try reseting the alarm,maybe all thats needed.....
May 01, 2010 | 2000 Toyota Celica
#5 cylinder misfire-where is the #5 cylinder
Drivers side front cylinder. You should really have a qualified person to work on this car.
Sep 16, 2009 | Mercedes-Benz S-Class Cars & Trucks
Cylinder Layout V8 5.9 L Magnum Dodge
drivers side plugs from front of engine to rear are cylinder numbers 1...3...5...7
passenger side front to rear 2...4...6...8..
fiing order 1..8..4..3..6..5..7..2..
Sep 07, 2008 | 1999 Dodge Durango
Mercedes S-class S500 Logo
62 people viewed this question
Top Mercedes-Benz Vehicle Parts & Accessories Experts
Marvin
Marvin
Jonah Oneal
xxxxxx xxx
Are you a Mercedes-Benz Vehicle Part and Accessory Expert? Answer questions, earn points and help others
