All the channels work great but the channel 36 doesn't have the volume but if you go to any other channel the volume is there. Could you give me some ideas why just this one channel has no volume
All the other TV's in the how will play the sound on channel 36 but the Panasonic Tv won't but the volume does work on all the other channels.
"Overdrive Channel: high frequency noise as the gain and volume are increased."
This is the expected result, you are experiencing feedback. Try turning the "Contour" knob all the way to the left and turn down the tone knob on your guitar.
go into your menu and find closed caption, someone has accidently set the closed caption mode to text, when the on screen display of channel or volume goes away the box appears. turn off the closed caption feature or switch it to something other than "text" mode, and your box will go away.
I pressed some key on my remote accidently and thereon i have not been able to move to any other channel except adjusting the volume in this one...pls suggest...I do not know if this got locked..
search on its manual if if has a LOCK feature! if it is lock then it would be fixed on a single channel. Lock feature was designed to prevent children from playing with your TV channels and volume and everything on the remote!
Usually, this means that something has spilled into the front of the set and has contaminated the pushbuttons. If one of the channel pushbuttons has fluid in it, the set will just sit there searching for channels and will not respond to any other commands. The computer thinks you are pushing the channel button and responds accordingly. When you push another button the computer does nothing because it thinks that you are pressing 2 buttons at the same time. The board should be cleaned and any contaminated pushbuttons replaced by a qualified tech.
