Is this a FRONT LOADER? Or, a TOP LOADER?
The following link explains how to access and inspect the interior of a FRONT LOADER and what common sources of leaks to look for:
http://www.fixya.com/support/r3576656-washer_leak__front_loaderThe most common source of front loader leaks comes from the door bellow (gray rubber seal). A routine inspection around the perimeter of the door for rips or tears will tell if the bellow needs replaced. If the bellow requires replacement, the following link explains how:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_loadIf this is a TOP LOADER, the following link explains how to access and inspect the interior for common sources of leaks:
http://www.fixya.com/support/r3576648-washer_leak__top_loaderThe most common source of leaking on a TOP LOADER is the drain pump. These pumps are not serviceable and if found to be leaking, need to be replaced. The following link explains how:
http://www.fixya.com/support/r3794382-replacing_water_pump_whirlpool_topWhatever style washer you have, make sure you read through the links provided and follow the steps on how to properly access your washer interior so you can get an accurate view. Make sure you check all tub seals, dispenser hoses and drain hoses as well.
Replacement parts (if required) can be purchased from any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. the first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have questions, please post back with your MODEL NUMBER and let me know. I hope you find this information helpful.
