Canon PowerShot SX120IS Logo
A
Anne Posted on Mar 21, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What wrong is on canon powershot camera error E32 comes up
Changed battery, changed memory card - not help
Jay Plesset
Level 3:
  • Canon Master 2,942 Answers
  • Posted on May 27, 2015
Jay Plesset
Canon Master
Level 3:
Answers
2942
Questions
Helped
668471
Points
9879
Your camera likely needs repair:
SX280HS E32 error not video
5 Related Answers
Anonymous
  • 3 Answers
  • Posted on Jan 28, 2009
SOURCE: memory card error after inserting SDHC card on powershot A620
the a 620 only goes up to 2 gb no higher
Anonymous
  • 51 Answers
  • Posted on May 20, 2009
SOURCE: Camera reading memory card error, cannot get it to work. Tried removeing the card and replacing batteries. Checked and it is not locked.
try formatting the card once on a pc and then plug it in your camera....if that does not help either, you'll have to try a different card.
Anonymous
  • 11967 Answers
  • Posted on Oct 21, 2009
SOURCE: Canon powershot SD1200 IS says Memory Card Error
You probably just need to format the card in the camera. This will completely erase it so download any pictures you want to save first.
Anonymous
  • 30 Answers
  • Posted on May 29, 2010
SOURCE: Memory card error message
Cards are coming in different formats and it might be possible that you brought a card which is not suitable or functional with your camera. The other reason could be that we are having options to lock our memory card in digital camera and you might have taken out your earlier card without unlocking it. The system might be broken from inside and this could be a reason that you are still getting a message that memory card is locked. It seems possible based on problem you are sharing.
Petrica Voicu
  • 64 Answers
  • Posted on Jan 27, 2011
SOURCE: Canon Camera Error E32. Camera
The most common problems in these small tiny cameras is the lens alignment. If you drop the camera with the lens extended this alignment will ****. If you are a handyman you can fix it by yourself by oppening it inside and realign/putting the lens in right position. Sometimes you can do that by forcing them to extednd manualy but that is very risky. If not handyman I recomand you to take it to a repair shop.
What wrong if E32 error shows on canon powersht camera?
Check here for Canon Error Codes
http://www.canon.co.uk/support/consumer_products/product_ranges/cameras/eos/error_codes/
1helpful
E32
Is this a lens error or an error with the memory card? People seem to see this error for both cases.
If it occurs while recording a video or taking a photo:
  • Save your photos & videos onto your computer, then reformat your memory card.
If it is a lens error:
Best of Luck!
1helpful
I have a Canon PowerShot A460. IT is giving me a "No Memory Card" error. The card if 4 years old. I purchased a new one and changed the batteries in the camera and it is still giving me the...
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. Other causes include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
When i turn it on Memory card error comes up, i have changed cards, both cards worked fine before, cannot format card using camera as FORMAT is greyed out in menu and just skips over it.maybe needs reload...
Please have the memory cards checked on with another PC and if detected have the cards formatted. If so check your PC for any virus in the OS.
If there is no detection of the memory card then it is possible that the card detection slot reader is not contacting or a possible software error in the camera.
Please log on to the Canon support for help:
http://www.canon.com/
3helpful
How do I solve error e32 on my canon powershot sx210?
The following is an answer taken from site: http://answers.yahoo.com/question/index?qid=20101220203847AAmODI4
"You can try a hard restart:
- put fresh batteries in the camera but no memory card;
- double click the on/off button so the camera turns on, then off;
- hit the button again and, hopefully, it will start normally.
If this doesn't help, call Canon tech support. E-series error codes may indicate hardware or firmware issues that need professional repair. In the U.S. the Canon customer support phone number is: 1-800-OK-CANON."
Hope this will help. Best of luck.
5helpful
2answers
E32
Since your camera is a Canon and you are experiencing an error code, we'd refer you to this site: www.camerasandparts.com They just do the Canons, they aren't expensive at all and the work through them on the Powershots is superb! They'd be the place to help you on this one. Most of their service packages for the error codes are $89 with the parts / labor included , the servicing for the camera is covered, plus the shipping on the way back is covered. The best part with them is their work is excellent on the Canons. Hopefully that helps to get you going with it.
"lens error, restart camera" for canon powershot SD1200IS
problem in canon digital camera ixus 95 is
Do not open Power has never changed the battery and another also does not start
Memory card error canon powershot S3 IS
Sounds like the camera may need to be sent into canon to be fixed. I had to do that once- they allow you to track the camera from the moment they receive it- till the moment it is fixed. It was not so bad.
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
