Cars & Trucks Logo
A
Alex Posted on Mar 21, 2015
What is wrong if my mercedes s 500 1995 v8 is running on 4 cylinders only.I have checked the spark plugs, plugwiers ,two destibutors and routers and thy seam to be allrite .The car has got two coils asswel
digitalarmsd
Level 1:
  • Contributor 20 Answers
  • Posted on Mar 21, 2015
 digitalarmsd
Contributor
Level 1:
Answers
20
Questions
Helped
13725
Points
36
With the little information you provided, My first suggestion in s a faulty pick-up coil in one of the distributors. Because you are missing half of your cylinders, your problem is likely isolated to one of the two distributors. If the Cap/rotor are good on both, the pick up coil (or equivalent) in one of the distributors may be faulty and will cause all the plugs on it to not fire.
Running on two cylinders
The removal of # 3 & # 4 tells you those cylinders are
contributing the most ,as removing the wire causes the motor
to stop
My guess is that the other cyl #1 & #2 are not firing at all, if there
is no change
If you had a V6 or V8 it would continue to run,not so with only
4 cylinder
Learn or study the ignition system & replace any ignition control
module that fires the first two cylinders
Get an HEI Test Spark Plug & put the plug wire to that & ground it
& see if you get spark,check all the plug wires one at a time.
Don't forget timing belts that are worn & slip,battery voltage,alternator output & A/C Ripple coming out of it
I would check compression or better yet, do a cylinder leak down test.
Could be you have worn valves in #1 & #2 thus little spark
Check fuel pressure at motor with a gauge
I have a 2000 dodge Dakota with the 5.9 v8 my ecu was not reading to my obd2 scanner so I replaced the ecu now that I have done that it sill wont start my fuel pump is priming and my spark plugs are wet I...
What about spark plugs and plug wires on those two cylinders with no spark? This is a v8 engine, you didn't mention the other cylinders? The rotor turns when you crank it?
Hello i have a 1993 Mercedes Benz 400sel. i have changed the distributor caps, rotors, and spark plugs/wires. it is only running on 4 cylinders right, now and i don't know why. There is no spark on all 4...
Hi Atsy,
I'd believe that the problem could be a bent distributor cam shaft (The center shaft inside the distributor.
Have it checked and if I've been a clever boy you can give me a rating
Regards Johngee10
HI, did you try checking the ignition coils. I had the same problem in my car I replace the one ignition coil where there was no power and that solve the problem. try not to buy cheap ones those will blow fast. you can find the Bosh original ones in the internet for a fare price. today at the dealer are about $212.00 each.
11helpful
2003 mercedes Benz C240 codes P0300, P0301, P0302 and P0303. Please, help me how to fix?.
P0300 Random Misfire Detected
P0301 Cylinder 1 Misfire Detected
P0302 Cylinder 2 Misfire Detected
P0303 Cylinder 3 Misfire Detected
according to this fault codes first mark ignition coils
3 ---------------- 6
2 ---------------- 5
1 ---------------- 4
RB-------------LB
this right banks and left bank, please remove Ignition coils with lids and spark plugs from right bank and swap with left bank, if fault code change as
P 0304 Cylinder 4 Misfire Detected
P 0305 Cylinder 5 Misfire Detected
P 0306 Cylinder 6 Misfire Detected
You can Identify it's a faulty ignition system then next swap ignition lids from ignition coils be careful each coils have two lids one short and other long bit deference and when you remove and fix it to the car keep in mind correct order because each coil two different fire for two spark plugs don't mix up, if you mix it can create the fault code.if you detect any fault ignition coils or spark plugs or lids replace that and also whether god or bad recommend to replace spark plugs, find the right that's most important thing, if this way couldn't found the any ignition fault next step is check fuel presser, when the engine running fuel presser must be around 4.5 bar without engine running must be 4 to 6 bar if the fuel presser too low need to check two different things one is fuel pump other is fuel injectors, in this case you can swap injectors from right bank to left bank and find is the injectors leaking, if not leaking faulty fuel pump.is this information helped you? if yes please leave a comment,
3helpful
Spark plug firing order Diagram
For the 1984 Ford F150:
I do not know if you have the 4.9L In-Line (Straight) 6-Cylinder, the 5.0L V8, or the 5.8L V8; however I have included all below.
For the 4.9L In-Line 6-Cylinder:
Firing Order
1-5-3-6-2-4
Cylinders:
(back)
...6
...5
...4
...3
...2
...1
(front)
Distributor:
...........4
.....2
[].............1
..6.............[]-clip
.............5
.....3
Rotation: Clockwise
For the 5.0L V8:
Firing Order:
1-5-4-2-6-3-7-8
Cylinders:
........(back).......
|...4...|......|...8...|
|...3...|......|...7...|
|...2...|......|...6...|
|...1...|......|...5...|
.......(front)
Distributor:
..[]....5...1
4................8
2................7
....6....3..[]-clip
Rotation: Counter Clockwise
For the 5.8L V8:
Firing Order:
1-3-7-2-6-5-4-8
Cylinders:
........(back)........
|...4...|.......|...8...|
|...3...|.......|...7...|
|...2...|.......|...6...|
|...1...|.......|...5...|
........(front)
Distributor:
..[]..3....1
7..............8
2..............4
....6....5..[]-clip
Rotation: Counter Clockwise.
Let me know if this helped, or if you have additional information or questions. Feel Free to contact me at FixYa.com!
1992 Mercedes-Benz Mercedes Benz 400... Problem:
Hello, What you could have is and ignition problem. I have had to replace many distributor caps (2) and rotor buttons (2) on this model to solve this same problem.
I hope this helps.
CYA, Gtaor241
2answers
P0304=misfire in cylinder 4. coil? spark plug? spark plug wiring. 1999 crown vic 4.6 V8. runs ok, just little cutting out every now and then.
not coil coil it wouldnt fire at all it is either a plug or a wire replace the wire and plugs and that will fix it
Top Mercedes-Benz Experts
ZJ Limited
ZJ Limited
xxxxxx xxx
Arnie Burke
Arnie Burke
Are you a Mercedes-Benz Expert? Answer questions, earn points and help others
