SOURCE: Set time on tghk watch
As there are no possible watch manuals for unknown brands, all I can say is:Click on my profile (escapement), then click on Tips and Tricks. There you will find links to all watch manuals.Go through all and you will find the right one, as all watches stand on globally accepted basics. It may take some time, but at the very end you will get what you want.Rate me, please
SOURCE: My TGHK watch is stuck in ''Military Time''...
advance the hours. The first time you go through the 24 hour cycle, it will be in am pm mode, the second time in 24 hour mode, the next time in am pm. Just keep advancing the hours until it comes up the correct time
SOURCE: TGHK hourly chime, and military time
Go to alarm screen and press light and st/sp at the same time.
SOURCE: Need to set time on WalMart TGHK watch.
Use the Mode button to get to the time display. The seconds should be flashing. Then press the Reset button once and the Hours should flash. Use the ST/SP button to increment through the hours. When the hour is correct, press the Reset button again the get to the flashing minutes display. Go through these steps until all items are set the way you want them.
The alarm is done similarly by pressing the Mode button until the AL displayes and if in small font the ALM and/or CHI display next to the AL, you can turn them off by pressing the reset button until both are off. If you do want the Alarm and time set then leave ALM set but set the time using the reset button to get the hours flashing or minutes flashing and use the ST/SP to increment to hour/min you want. Finish the sequence by pressing the Mode button once. If the ALM or CHI are set, then in the Time display you will see the ALM and/or CHI indication next the day of the week.
