Jaguar 1998 XJ8 Radio a1z107373 CD changer Logo
Anonymous Posted on Mar 20, 2015
No AM, how to fix?
New rear antenna, tried 3 radios correct codes FM worked but not AM. Wiring, fuse, switch??
Frederick Electrick
Level 3:
Master:
  • Master 350 Answers
  • Posted on Mar 20, 2015
Frederick Electrick
Master
Level 3:
Master:
Answers
350
Questions
Helped
107237
Points
1344
The FM antana is different wires and contraction point on the radio, than the AM antana
Check all connections, would need more radio information to answer further...
Hope this helps?
Mai Lor
Level 3:
Genius:
  • Jaguar Master 2,558 Answers
Mai Lor
Jaguar Master
Level 3:
Genius:
Answers
2558
Questions
0
Helped
524623
Points
7053
-Read its manual before do more.
Good Luck
mai
1helpful
Why does my radio not work in my kenwood TT756sl radio toaster, how do i fix it
May have fuse blown, check fuses. Antenna may be disconnected.
Radio wiring may have come loose on back of stereo. Check all.
2answers
Hi i have a 95 buick lesabre i bought from a friend everything works great sides the radio i have an after market stereo jvc model no kd-g320 not sure witch color the antenna wire would be car has a power...
Antennae wire and other wires for the stock stereo are listed below:
1995 Buick LeSabre Stock Radio Wiring Diagram
Car Radio Constant 12V+ Wire: Orange
Car Radio Ignition Switched 12V+ Wire: Yellow
Car Radio Ground Wire: Black/White
Stereo Radio Illumination Wire: Gray/Black
Stereo Radio Dimmer Wire: Brown/White
Stereo Radio Antenna Trigger Wire: Dark Green
Stereo Radio Amplifier Trigger Wire: N/A
Front Speakers Size: 5 1/4? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Front Speakers Location: Doors
Left Front Speaker Wire (+): Tan
Left Front Speaker Wire (-): Gray
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Dark Green
Rear Speakers Size: 6? x 9? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Brown
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Dark Blue
Right Rear Speaker Wire (-): Light Blue
Am radio not working
If I remember correctly, FM and AM tuners are separate devices with separate antennas. Both devices are located in the trunk. Check antenna connections and fuses, then try with diagnostic tool and look for error codes.
2003 bmw 525i radio
have the radio checked out as the band change switch is not working. Try going into the mode /menu section of the radio and adjusting it there . Changing antenna does nothing as the radio works on either band with the same antenna
I was attempting to install a new stereo in my 2000 taurus. it requires to an adapter to put the new stereo in. i got the new adapter and stereo in *kinda* but decided i didnt really know what i was...
check your fuses first. You may have blown one.
Visual Inspection Chart Mechanical Electrical
  • Integrated control panel (ICP) physically damaged, misaligned, any control(s) inoperative
  • Digital audio compact disc player physically damaged, misaligned, any control(s) inoperative
  • Antenna or antenna cable physically damaged, misaligned connection(s)
  • Radio speakers, mounting/speaker cones physically damaged, misaligned
  • Radio ignition interference capacitors, radio frequency interference suppression bond misaligned (also check for cleanliness and metal-to-metal contact)
  • Battery junction box (BJB) fuses F127 (5A), F117 (20A), F127 (5A).
  • Central junction box (CJB) fuse F227 (10A) F211 (15A), F216 (15A), F226 (10A) (wagon only)
  1. If the fault is not visually evident, proceed to diagnose the integrated control panel (ICP) by entering the ICP Self-Diagnostic Mode.
NOTE: To enter the ICP Self-Diagnostic Mode, the ICP must be ON and in radio tuner mode (AM/FM).
  1. Enter the diagnostic mode by pressing and holding preset buttons 3 and 6 simultaneously. This will suspend all radio functions, and display SP.
  1. Preset Button 1 = Audio internal/external SELF TEST. The display will flash SELF while gathering the diagnostic trouble codes (DTCs), then stop flashing when complete. Press the TUNE UP button to display the DTCs if any exist. Record codes and refer to the following table:
ICP SELF-TEST CODES Code Description 0 No diagnostic trouble codes logged 1 No response from rear chassis unit (RCU) 2 No response from cassette player 3 - 4 No response from compact disc player 5 - 6 - 7 No response from remote climate control 8 - 9 Read Only Memory Verification failed
  1. Preset Button 2 = Displays the feature strap for code identification, refer to the following table.
Code Description 01 Base-Electronic Search Radio (ESR) with Manual Climate Control (MCC) 07 Electronic Search Radio with Cassette (ESC) with MCC 17 ESC with Electronic Automatic Temperature Control (EATC) 97 Not programmed default of ESC with EATC
  1. Preset Button 3 = ICP and RCU identification. This test identifies the software level of the ICP and RCU. The ICP is tested first, followed by the RCU. The display will have two sequences of three codes each. The first sequence is for the ICP, the second sequence is for the RCU. For code identification, refer to the following table:
Item Part Number Description 1 - Product variant code 2 - Tape model 3 - CDR
SOFTWARE IDENTIFICATION CODES Product Type Code Description Product Variant Code Description 21 ICP 07
08
09
10
11
12 EATC with AM/FM, cassette player and CD changer
EATC with AM/FM and cassette player
Manual A/C with AM/FM and cassette player
EATC with AM/FM cassette player and CD changer 31 RCU 01
02
03 Analog
Digital
Midline 71 Remote climate control 01 LH drive 52 Compact disc/disc jockey 01
02
03
04 Sony® 10 disc
Sony® 6 disc
Clarion® 6 disc
FMS 6 disc
3helpful
2answers
Need a wireing diagramfor toyota camry 95 for car radio the coloers dont match the new radio wire harnest
1995 Toyota Camry Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Blue/Yellow
Radio Switched 12V+ Wire: Gray
Radio Ground Wire: Brown
Radio Illumination Wire: Green
Radio Dimmer Wire: N/A
Radio Antenna Trigger Wire: Black/Red
Radio Amp Trigger Wire: None
Front Speakers Size: 5 1/4′
Left Front Speaker Wire (+): Pink
Left Front Speaker Wire (-): Purple
Right Front Speaker Wire (-): Blue
Rear Speakers Size: 6′ x 9′
Left Rear Speaker Wire (+): Black
Right Rear Speaker Wire (+): Red
Right Rear Speaker Wire (-): White
5helpful
Radio wiring diagram for a 96 thunderbird with premium sound
1996 Ford Thunderbird Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Black/Orange
Radio Ignition Switched 12V+ Wire: Yellow/Black
Radio Ground Wire: Black/Light Green
Radio Illumination Dimmer Wire: Light Green
Radio Antenna Trigger Wire: N/A
Radio Amplifier Trigger Wire: Dark Blue
Front Speakers Size: 5′ x 7′
Left Front Speaker Wire (+): Orange/Light Green
Left Front Speaker Wire (-): Light Blue/White
Right Front Speaker Wire (+): White/Green
Right Front Speaker Wire (-): Green/Orange
Rear Speakers Size: 5′ x 7′
Rear Speakers Location: Side Panels
Left Rear Speaker Wire (+): Gray/Light Blue
Left Rear Speaker Wire (-): Tan/Yellow
Right Rear Speaker Wire (+): Orange/Red
Right Rear Speaker Wire (-): Brown/Pink
Radio and clock will not work. The fuses are good i think.
Check fuses first. please rate as fixed if this solves you rissue. report back results.
VISUAL INSPECTION CHART
  • Integrated control panel with or without tape player physically damaged, misaligned, any controls inoperative.
  • Digital audio compact disc player physically damaged, misaligned, any controls inoperative.
  • Radio antenna lead in cable, electric antenna or bodyphysically damaged or misaligned connections.
  • Radio speaker mounting/speaker cones physically damaged, misaligned.
  • Radio ignition interference capacitor or radio frequency interference suppression bond misaligned, unclean and no metal-to-metal contact.
  • Mobile telephone transceiver; mobile telephone handset, mobile telephone microphone, mobile telephone transceiver holder cradle physically damaged, misaligned.
  • Open fuses: fuse junction panel fuses 8 (5A), 12 (5A), 20 (5A), 22 (5A), 24 (5A) or power distribution box fuse 17 (20A).
  • Open connectors.
  • Corroded connectors.
Section 15-00: Audio Systems—Service 1999 Taurus, Sable Workshop Manual DIAGNOSIS AND TESTING Inspection and Verification NOTE: Many customers do not understand the limitations of FM reception. Refer the customer to the Owner Guide for information about the limitations of FM radio performance.
Internal diagnostic examination of the integrated control panel, rear chassis unit and audio compact disc player should be left to the authorized radio service center. However, the automotive technician should be able to analyze and isolate radio reception conditions to the proper area or component causing the condition. All radio conditions can be isolated to one of six general areas:
  • antenna system
  • integrated control unit
  • radio speaker system
  • radio noise suppression equipment
  • rear chassis unit
  • audio communications protocol network
Retrieving Diagnostic Trouble Codes (DTCs)
Using Audio System On-Board Diagnostics
The audio system has on-board diagnostic capabilities and is equipped to check for every component available in the system even if this specific vehicle is not equipped with all components. A Diagnostic Trouble Code (DTC) will be set for the missing components. These DTCs can be ignored if the vehicle is not equipped with these components. The battery must be fully charged for proper audio system operation. The ignition switch must be in the RUN or ACC position. Turn the system on, tune in a strong AM station and verify good reception. After an AM station is checked, tune in a strong FM station. The system is now ready to enter the diagnostic mode. Diagnostic Mode:
NOTE: Battery must be fully charged for proper audio system operation and self-test.
Enter Diagnostics mode by pressing SEEK DOWN button first and then pre-set button 3. Hold both buttons for five seconds. This will suspend all normal radio functions, retain the previously selected frequency and display DIAG.
  1. NOTE: To perform diagnostics, press the appropriate buttons as instructed.
    SYSTEM CONFIGURATION SELF-TEST:
    Press pre-set button 1. This will check for connection of all possible devices and log the diagnostic trouble codes for any device that does not respond. The display will flash SELF while gathering the diagnostic trouble codes, then stop flashing when complete. To exit System Configuration Self-test, press pre-set button 1 again. To retrieve diagnostic trouble codes, press the TUNE UP button. This will display the diagnostic trouble codes if any exist. Continued pressing of the TUNE UP button will display the next diagnostic trouble code. Record codes and refer to the following table. To exit the Retrieval Mode, press pre-set button 1.
    CONFIGURATION SELF-TEST CODES Code Description 0 No diagnostic trouble codes logged 1 No response from rear chassis unit 2 No response from tape deck 3 No response from bezel microprocessor 4 No response from compact disc player 5 No response from steering wheel controls 6 No response from rear seat control 7 No response from remote climate control 8 No response from navigation module 9 Read Only Memory verification failed
    Remember, system configuration will test for all possible equipment connections. Inspect the vehicle to determine actual equipment installed.
  1. Integrated control panel display test:
    To enter the integrated control panel display test, press pre-set button 5. This check will light all segments in the integrated control panel. The system will automatically exit this test after five seconds.
  1. Integrated control panel and rear chassis unit identification:
    To enter this test, press pre-set button 3. This test identifies the software level of the integrated control panel and rear chassis unit. The integrated control panel is tested first, followed by the rear chassis unit. The completed test will exit automatically. For code identification, refer to the following table. The display will have two sequences of five codes each. The first sequence is for the integrated control panel, the second sequence is for the rear chassis unit.
    Item Part Number Description 1 — Product Type Code 2 — Product Variant Code 3 — Software Version Level 4 — Software Version Release 5 — Software Version Patch
I just purchased a 1990 nissan 240sx and want to replace the radio with a new cd receiver. how do i remove the old radio? it is an am/fm with a cassette player below it.
Just remove these trim pieces (start with the ash tray) I have also included the wiring list
Wiring
Constant 12V+: Red/Black
Switched 12V+: Blue
Ground: Chassis
Illumination: Red/Blue
Dimmer: Red/Yellow
Antenna Trigger: Black/Red
Antenna Left Rear
Front Speakers 4" x 6" Doors
Left Front (+): Blue/White
Left Front (-): Blue/Yellow
Right Front (+): Brown
Right Front (-): Brown/White
Rear Speakers 6 1/2" Rear Deck
Left Rear (+): Red
Left Rear (-): Green
Right Rear (+): Blue
Right Rear (-): Pink
Please rate this a fixya
AM reception
If the internal antenna is broken that means the ferrite bar is broken,that does imply that the wiring around it is cut. If the two parts are not removed, the antenna may still be able to perform correctly (just as two magnets put end to end). You can try to put it in the vicinity of another radio to see if there is any resonance effect.
Hope it helps.
Top Jaguar Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Jaguar Audio Player and Recorder Expert? Answer questions, earn points and help others
