We don't have much information to go on, like how is it not stitching. Is the machine actually functioning (needle going up & down, feed dogs moving, is the motor working, is it acting like it's stitching but the threads are not forming a stitch?)
Sounds like you've got a thread jam going on in the bobbin case area. Good cleaning and a new needle will probably fix it. See: https://answers.yahoo.com/question/index?qid=20091202121550AAHxN8y
Wow. If I understand your attempt at English. Your machine made a noise and now won't sew or pick up the bobbin thread.
First change your needle and make sure it's full inserted and correctly oriented in the needle bar. Do a test stitch on scrap fabric.
If you still have problems.. check the timing. The shuttle hook should just be starting to pass the needle scarf when the needle is at the lowest point of travel.
try changing the needle rethread the machine top & bobbin if the suggestions don't work, it's possible that the machine may have jumped time,, taking it to a sewing machine shop the technican can tell you for sure
is it possible that the needles are in backwards? it's very possible that the machine is out of time & would have to be taken to a sewing machine repair shop to be retimed
wow, taking apart and putting it back together is a big feat. I think you should check the needle and its height, could be to low and is hitting just enough to make noise and not break.
