Question about Samsung UN60EH6003 60" 1080p LED HDTV, 1920x1080, Clear Motion Rate 240, 20W Stereo Speakers
Led tv goes black
My screen goes black after 15 minutes of viewing. Screen returns to normal after turning tv off then back on. After 5 minutes, the tv goes black again. The audio works fine, just the video is out.
SOURCE:
  • 34 Answers
SOURCE: Samsung LCD flat screen goes black. Turn tv off
Sounds like your power board is failing. contact samsung tech support and describe your problem. some parts on samsung have lifetime warranties and the service call is free.
Posted on Apr 09, 2009
  • 30 Answers
SOURCE: Blank Screen but sound works on samsung HPS-S5053
Testing by FixYa Staff
Please do not rate this post!
We apologize for any inconvenience.
Posted on Jul 14, 2009
  • 147 Answers
SOURCE: BOTTOM HALF OF SCREEN GOES BLACK R A MINUTE OR SO
remove the back of the tv.disconnect and reconnect the ribbon cables into your buffer pcb.if this does not correct the problem replace the buffer pcb in that location where the screen is going black.you also could have
a defective panel if the buffer pcb does not correct your problem.
Posted on Jul 17, 2009
Geekman
  • 32281 Answers
SOURCE: Flashing screen when i first turn on my... but turns black immedi
You could have a faulty inverter board or faulty CCFL lamp which can cause the screen to flash.
Check out LCD Parts for service, parts and DIY info - click on this link to their WEB site. :-
www.lcdparts.net
Posted on Sep 30, 2009
tvtek
  • 1284 Answers
SOURCE: my samsung tv hlr5067wx/xaa screen turns black,
I suspect the lamp is failing on your TV. The lamp replacement code is listed on the side of the TV on a sticker that is orange and white. It will start with BP96-. The lamp code is crucial on these older Samsung DLP's because they used quite a few different styles. Please take a few moments to rate my answer. Thank you...
Posted on Nov 19, 2009
Lc-60le835u screen going black,turned off for minute,turn back on okay for 15 minutes then screen goes black again, now screen is always black the sound is ok,need 2 know what it is I need to replace?
I would only guess on this without testing it and having a repair guide, but the PCB that controls the screen display is called the "T-Con" PCB
Nov 04, 2016 | Sharp Lc-60le835u Led Tv
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
Soniq PT42SH plasma TV power on. No back light and no pictures
SONIQ LCD TV REPAIR Blank flickering screen Energy ...
? 1:32
https://www.youtube.com/watch?v=FUqdi7lwmcE
May 29, 2013 - Uploaded by WastedOne2
Fix ya Soniq Tv once loaded up hit menu button then channel + then ... SONIQ LCD TV REPAIR Blank flickering screen Energy Saving Mode Issue ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't turn on] ... Common easy LCD TV fix: bad picture screen rainbow colors - Duration: 4:04.
No Image & Blank Black Screen Flashlight Test - YouTube
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to Fix LCD & LED TVs ... Most LED TVs will have a t-con board, a power supply board, a main board and an LED ..... SONIQ Australia 1,718 views.
Soniq PT42SH plasma TV power on. No back light and no ...
Jan 08, 2016 | Televison & Video
LED screen comes on and goes black
LG LCD TV REPAIR - NO PICTURE SCREEN FIX REVIEW ...
? 5:29
https://www.youtube.com/watch?v=PWoz_-3OHIM
Jan 25, 2013 - Uploaded by Tampatec
Common LG LCD TV REPAIR - NO PICTURE OR BLACK SCREEN FIX ... I have a LG 42PM4700-UB plasma tv that justwent black. The red ... I had to keep turning on and off the TVseveral times for the screen to come back.
LCD & LED TV Repair - No Image & Blank Black Screen ...
? 5:56
LED & LCD TV How to Diagnose Symptom of No Image on theScreen CLICK ... Tv was working fine when left to go to store and came back to blank picture and ... my samsung tv it turns on but its completely black and no sound at all ... LG LCD TV REPAIR - NO PICTURE SCREEN FIX REVIEW - Duration: ...
LG LED TV has no picture (black screen) but still sound ...
Dec 09, 2015 | LG 47LS4500
TV goes to blank screen after turning it on (about 3 to 4 minutes) but I can still hear it fine. I turn it off and wait a few minutes(5) then turn it back on everything is normal then it goes back to blank...
This tv the LCD inverter board is dead,that why is not sustanning backlight for the LCD screen light to have the picture.Call Polaroid for warrenty repair,this tv under a year old.
Jun 07, 2010 | Polaroid TLA-01511C 15 in. LCD Television
Half the tv screen goes black randomly,then returns to normal
The Tuner signal board have problems.The board CPU,Chip,have intermitten short.When the chip is completely dead.The tv will get only LED light indicator power only,will not get tv signal pictures.
Apr 12, 2010 | LG 42LC2D 42 in. LCD HDTV
Problem With KENMARK flat Screen TV - BLACKS OUT
you do not give the model number for a better diagnosis
the most common cause of this problem is the invertor or at worse the screen its self.
If it is a lvd 163 you can purchase a new invertor from sales@tvs-services or call 01245392539
Feb 14, 2010 | Zenith IQC50H95W 50" Rear Projection...
Screen Goes Green TV goes to stand by blinking 8 times
try adjusting your color tuners located inside tv behind speakers.
Nov 25, 2008 | Sony KP-57WS500 57" Rear Projection...
Screen tuns black after 15 seconds and comes back after about 15 minuts
The solder joints on the vertical output IC have cracked. This is a very common problem on those sets.
Nov 14, 2006 | Panasonic CT-27G34 27" TV
Samsung UN60EH6003 60" 1080p LED HDTV, 1920x1080, Clear Motion Rate 240, 20W Stereo Speakers Logo
482 people viewed this question
Top Samsung Car Audio & Video Experts
Marvin
Marvin
Vernon Taylor
Are you a Samsung Car Audio and Video Expert? Answer questions, earn points and help others
