Question about Speed Queen Washing Machines
How do i fix my washer
It want start washing just make a harming nois sound
    Genius:
  • Speed Queen Master
  • 1,585 Answers
Start up capacitor motor
Posted on Mar 22, 2015
SOURCE:
Manual for ge washer:wslp1100a0wh is there a PDF DLL for this manual?
Try Googling (GE)(wslp1100a0wh)(manual) without parens. Before using WD-40 on the sensor next time, bear in mind that it is electrically conductive and may do more harm than good.
Dec 24, 2017 | GE Washing Machines
Makes noies on spin cycle
check the racers and water seal in inside the wash tub.......or tub mounting bracket.....
May 25, 2013 | LG WM-2277HW Front Load Washer
Washer is making a terrible sound, I think it is a loose or worn drive belt because it does not agitate or spin properly
is the nois a grinding, whirring noise? I think the motor coupling has gone bad. Not an extremely hard repair and a repair man should only charge around $25.00 for the part and his service call. You can do this yourself if your mechanically inclined. the coupling is under the drum and you have to take the front cover off to get to it.
Nov 28, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Washer won't spin during rinse cycle. agitates fine during was cycle.
The lid switch is probably your culprit. the washer won't spin or drain if the lid switch is defective. Try pushing down on it with a pen or small screwdriver and see if it will spin then. There should be a slight clicking nois when it is activated, although it will sometimes click even though it is not working.
Nov 15, 2010 | Whirlpool LSR5132PQ Top Load Washer
Does'nt cycle properly
Hi.
this is a failed timer device. By replacing the timer control module it will eliminate these issues you are having and ur problem will get solved...
thank u
rate me!!!
Jun 01, 2009 | GE WBSR3140DW Top Load Washer
The washer is not runing
The door locking mechanism may need replacing. IF the door doe snot shut properly, it does not complete a circuit on the main control board and the washer will not advance to the next electronic cycle. IN this case, fill.....Check your door switch and repair or replace as needed. If I can help further. Eric Campion
Feb 21, 2009 | Frigidaire ATF6000ES Front Load Washer
My washer when it is working is jumping when it is spining realy
Check/replace the vibration damper rods.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 10, 2009 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
82 people viewed this question
Top Speed Queen Washing Machines Experts
Poppa Maddo
Poppa Maddo
Marvin
Marvin
Paul Bade
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
