Try switch off and on see if it persist then then try hard reset U tried hard reset it by holding the power button and volume when tablet off then going down to factory reset by using down button and press power button ok go down to yes and that will hard reset but make sure u back Ur tablet up before u perform an hard reset
a repair might cost more than the tablet did
if it no longer responds to your finger maybe broke digitizer
you could do a factory reset. and hope it responds to your finger. Nextbook Android Tablet Hard Reset
iF THEDEVICE HAS FROZEN AFTER A RESET IT MUST HAVE HAD A FAULT BEFORE YOU ATTEMPTED THE PROCEDURE.
aT THIS POINT YOU SHOULD REFER TO THE MANUFACTURER FOR SUPPORT IN THIS MATTER. The reset procedure is there for the end user to correct minor faults at a low level, it corrects such faults where there is no hardware fault or where the software has no fundamental installation issues. If the hard reset has not corrected the issue one or both of these issues must be present.
The manufacturer should ne able to advise you on further action
Holding the power button down for 10-15 seconds is considered a hard reset on most tablets. If it still won't load you can try doing a factory restore.
Make sure the tablet is powered off
Briefly tap the power button once, then hold the power button and volume down until you get the boot menu
There should be an option to factory reset or something to that affect
If your Samsung GT-P1000 Galaxy TAB is frozen and unresponsive, press and hold [POWER ] for 8-10 seconds. The device will reboot automatically. If this does not solve the problem, perform a factory data reset. In Menu mode, select Settings ? Privacy ? Factory data reset ? Reset phone ? Erase everything
