Hi john bryant, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? What product? Brand? Model? OS?Hi john bryant, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? What product? Brand? Model? OS?
You can't post conmments that contain an email address.
Blown head gasket is a big job, I have had great success using some of the head gasket sealers, These products are not 100 percent for sure fix but work most of the time if the directions are followed correctly. Bars liquid glass has fixed the head gaskets in two cars ive owned when it works, it a permenant seal. Follow directions, and its best to remove the thermostate when using head gasket sealers.
I haven't worked on Paxar products, but the manual directions seem reasonably complete, with drawings. (PDF pages 17-22 provide the basic directions; the following pages give directions for special media types and options.)
Error #756 = "Load Supplies"
I deduce from this that somehow you missed the paper detector when you loaded the supply strip. This is probably the "die cut sensor" referenced on page 2.3 (PDF page 19, shown in drawing on the next page). Make sure the strip feeds through the detector slot.
Steps:
1. Get yourself register over there.
2. Then find out your product and you will definitely get the directions for use.
I guess it would be helpful for you.
Good day
cheers
Your product should have come with a USB cord that connects to a computer. Just plug the usb cord into the product and into the computer and it should start charging automatically. The directions for charging the product is listed in the product manual that came with the product. Refer to those directions.
You need to download and install the audio driver for your laptop, by following these directions: You can download your audio drivers from HP's Software and Driver Downloads page here: http://welcome.hp.com/country/us/en/support_task.html?pageDisplay=drivers Type in the product number of your computer in the product field and press enter. On the next page, click on the link corresponding to your exact product. In the first field, select the Operating System (be sure to select the 32- or 64-bit version correctly) you will be using with these drivers. Next find the newest driver in the list of drivers available for this product and click on the linked text of the driver. This will take you to a new page that gives the exact directions to complete the installation of the driver you need. You may need to restart your computer after this installation, and your sound will probably not work until you have restarted. Your sound device will now work! please rate my solution
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
1- Remove the mirror trim cover above the front of tRe
door panel. 2- If you're working on a,model with electric mirrors,
remove the' door trim panel and the watershield . Follow the harness
and disconnect the electrical connector from the mirror. 3- Remove the dust shield and rubber plugs for access,
then remove the mirror retaining nuts and detach the mirror from the vehicle. 4- Installation is the reverse of removal.
This is a website to help consumers with products,We do not sell,buy,or manufacture and products,You may want to contact the manufacturer or the location where you purchased it.
But here is a link where you can download the user manual
