SOURCE: SWR Cal meter is stuck
Passing a small magnet in front of the meter may be enough to free it up. It may, however, be an indication of a problem with the needle type bearing on either end of the shaft that supports the indicator or that the coiled indicator spring has broken.
SOURCE: Users manual for Magnum S-980 10 meter radio
Hello rickstaats, here is what your looking for,,,
http://www.cbtricks.com/radios/rflimited/magnum_s9/graphics/magnum_s9_om.pdf
and
http://www.cbtricks.com/radios/rflimited/magmun_980/graphics/s980_om_addendum.pdf
Compliments of CB Tricks,,, take care,,, Mechanic
SOURCE: SWR meter and varible power
It depends on what the model number is .... but take a look at this page and see if you can find some help with it
http://www.cbtricks.com/radios/galaxy/index.htm
SOURCE: swr meter not moving.
If the radio is working don't worry about the meter unless you absolutely want it. These little meters are not very accurate or reliable. Get an external SWR meter to check the antenna.
SOURCE: Very low TX output power on ALL HF BANDS ONLY. Other bands OK!
look for a broken or cracked board near the driver s & finals, try pushing around on the board with your plastic screwdriver, you may luck into it.
