Sruly-
I would take it to a repair center to have it evaluated. CONTACT US to get help locating a service center in your region.
Mark
Motorola Support
SOURCE: "Unauthorized Charger"
you can try to clean the charger port (but first make sure its not bent, or broken - the pins are really tiny and hard to see, so make sure)
But try cleaning the charge port on the phone and the charger with denatured (rubbing) alcohol, and a toothbrush -
Just make sure not to plug it in when you do this!
and clean both the charger and phone, make sure neither are bent
lastly, try a new charger!
NGK
SOURCE: Nokia N73 Music Edition Charges Forever
try factory reset ...... if that does not work get it checked with the nokia service center
SOURCE: my motorola hint phone says "unauthorized charger"
u have to turn off ur phone and then put the charger on..thts another way to fix it ..it can be any charger..u have to turn off ur phone then put the charger on
SOURCE: my motorola razor says unable to charge bought new
I had the same problem trying to charge with one
of those "universal" chargers. Then I find the original Motorola
charger and that solved the problem.
I hope this helps!
