Refrigerators Logo
n
naurora Posted on Mar 19, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My samsung frige, french doors keeo ringing
French doos the coolness numbers keep going uo and don
Jorgie the appliance guy
Level 3:
Top Expert:
  • Samsung Master 5,639 Answers
  • Posted on May 20, 2015
Samsung Master
Level 3:
Top Expert:
Answers
5639
Questions
Helped
1521784
Points
32630
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
Cause of Beeping Noise in Frigidaire Refrigerator eHow
My samsung frige, french doors keeo ringing - samsung-frige-french-doors-keeo-ringing-kvax0h5nolktkyinzrohy2he-2-0.jpg
samsung-frige-french-doors-keeo-ringing-kvax0h5nolktkyinzrohy2he-2-5.jpgMy samsung frige, french doors keeo ringing - samsung-frige-french-doors-keeo-ringing-kvax0h5nolktkyinzrohy2he-2-9.jpg-french-doors-keeo-ringing-kvax0h5nolktkyinzrohy2he-2-9.jpg
5 Related Answers
Anonymous
  • 116 Answers
  • Posted on Mar 11, 2007
SOURCE: Amana French Door Refrigerator "on" but no cooling; freezer still works
There are 2 possible problems. One is the defrost cycle is not working properly this is usually indicated by a large amount of frost on the back freezer panel. If so, the circuit will have to be repaired and the evaperator thawed to remove the ice build up. The other is the fresh food damper is not working properly this is behind the "lump" in the back of the fridge compartment above the top shelf, remove the louver panel to see if it is open or closed. closed will be warm open should be cold. The water dispenser reservoir is probably frozen due to poor air circulation.
Anonymous
  • Posted on Jun 28, 2008
SOURCE: Samsung french door fridge not working?
I had the same problem ("OF" on display and not working) and just found a fix and it worked (on SAMSUNG site).It was correctly stated that fridge is in "demo" mode. You need to push and hold POWER FREEZE and ENERGY SAVER buttons (not "Fridge button and the Power Cool buttons" as it was suggested above).
A
Anonymous
  • Posted on Nov 07, 2008
SOURCE: I have NEW sumsung ref. 25.5 french door with freezer at bottom
Had the same problem, your ice maker is a known defect, insist they replace it. Don't expect heavy ice output -- our biggest complaint.
Anonymous
  • Posted on Dec 07, 2008
SOURCE: Maytag refrig (french door) water and ice on door stopped.
1) Electric Water valve check up.
2) Water/Ice dispenser control check up
3) frozen plastic pipe inside door or/and chilled water container frozen
4) old water filter (clogged)
dragonsthatk
Albert Getty
  • 547 Answers
  • Posted on Feb 11, 2009
SOURCE: Installing upvc french doors and frame
you only want 1/8 th inch all the way around the door make sure to level hinged sides and shim them in make sure to constantley look by opening and closeing door that you have 1/8th all the way around
The ice maker in my Samsung French door refridgerator keeps getting frozen up. Help
hi Delunn.
this could be a couple of things wring.
so i think it best you go to this link and see if it helps you out.
ice maker in my Samsung French door refridgerator keeps getting frozen up...
2helpful
Samsung French door fridge is making an intermittent "whooshing" noise. It's still cooling and making ice and I don't see any frost or standing water in the fridge. Any thoughts or advice would be a
These fridges go through all sorts of cycles, the defrost cycle is probably the noisiest, strange sounds are ok, it will tell you when something serious is wrong, alerts & alarms.
Frige cool freezer warm
IS the compressor running and is it hot?
I CANT OPEN THE FRENCH DOOR
My guess it that they are frozen shut which means the little door heaters are not working or you have a bad door gasket. If you have a hair dryer I would blow it around the seams of the doors until they give. Or you can unplug the frige and let it thaw for a bit then try. Or the break between the frige air and the freezer may be frozen closed then the pressure difference can hold the doors shut, in that case you need to unplug it for a bit and try opening the doors periodically
Samsung french door freezer gets lots of frost inside - we've replaced the gasket but still get frost
Could be the rail slides not closeing correctly keeping door open slightly. Also they have made a new stronger set of rails to be used. Try going to the Samsung web site for tech info our recalls for that unit
Samsung french door refrigerator ice maker no dispenser defroster leaking water into bottom and produce drawers
If it is a frost free unit the water collects in a well at the compressor , there is a heater element in the well that boils off the water , this is were the fault is.
Samsung French Door Refrigerator not cooling
it's only 4 weeks old ./ don't mess with it it has a warranty you may void it if you work on it . it is probably in the main digital control in th fresh food .. but i would call the seller and they can set up a service for it .. mm
5helpful
5answers
Top Samsung Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
