HP Officejet 6310 All-In-One InkJet Printer Logo
p
pcanonici Posted on Mar 19, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Inserted 95 (color) ok but having trouble inserting 95.
Robbie Goodwin
Level 2:
Sergeant:
  • Expert 384 Answers
  • Posted on Mar 19, 2015
Robbie Goodwin
Expert
Level 2:
Sergeant:
Answers
384
Questions
0
Helped
88113
Points
989
Please specify what "trouble."
If you try another cartridge - including the old one - does that work, or have exactly the same "trouble", or what else happens, please?
Best wishes,
Robbie
Robert
Level 1:
New Friend:
  • Contributor 5 Answers
Robert
Contributor
Level 1:
New Friend:
Answers
5
Questions
0
Helped
761
Points
9
Wen you say having trouble inserting 95 do you mean the black cartridge? Please give more details.
Thanks,
Robert
My hitachi nt50ae2 will not work when I try to use 2 nails.
1) Oil it per the operating instructions.
2) Use only high-quality fasteners. I recommend Hitachi or Bostitch, although those from Harbor Freight Tools are largely trouble-free.
3) Make sure nails are properly inserted in the gun.
4) Check to confirm that your gun is receiving adequate air pressure. With that nailer, I'd suggest 95-105 psi.
2answers
What is error code C1-14
C1 14 MAIN CHARGER TROUBLE (COLOR)
You might be able to clean the charge wire.
https://www.sosnfl.com/sharp-mx-c312-error-codes/
Wont print copies it said documentation trouble shooting cartridges
Hi, first if you have just fitted them, open it up again and double check that they are properly inserted..
1helpful
Ez25eb-s error code U81
Hello
The display may not be U81. It may be C31. There are only three Self Diagnosis Dispay will be there, They are [C13, C31 & E XX]. If it is C31, DVD/CD inserted is not correct. Reinsert it correctly. If the same display comes again, open it and check whether the inserted disc spins or not. If the inserted disc does not spins; due to some other trouble, usually with the faut to sled motor; this display will be there. Check it. OK.
23helpful
4answers
Nokia 95 8gb china , showing invalid sim or sim
i have a china made mobile n8 but after inserted it shows invalid sim what's the solution of this problem
1helpful
My printer error says: Color cartridge inserted is not intended for use in this printer
That printer is intended to use the HP 95 and HP 97 cartridge. If anything other than these are inserted then it will not operate. Check to be sure your color is one of these two. If it is then you should take that cartridge back to where you bought it and get it exchanged or contact HP.
2helpful
How do I insert date on prints on my sony dsc-w50
You can use the supplied Picture Motion Browser (PMB) software to insert the Date on the images and then print the images with date.
Follow these steps to insert the date using PMB software:
  1. Start the Picture Motion Browser software.
  2. In the Picture Motion Browser window, browse to the folder directory that contains the images.
  3. Click to select the desired image.
  4. On the menu bar , click Manipulate .
  5. On the Manipulate drop-down menu, click View/Edit Media File .
  6. In open window, click the Edit icon.
  7. In the Edit drop-down menu, click Insert Date .
  8. In the Insert Date window, next to Display format , click the down arrow .
  9. Click to select the desired date or time format.
  10. Next to Color , click to select the desired color for the inserted date or time.
  11. Next to Position , click the down arrow .
  12. Click to select the position on the image you want the date or time to be inserted.
  13. Click the OK button.
  14. Close the image window.
  15. In the Picture Motion Browser dialog box, click the Save button to save the image with the inserted date or time.
  16. Click the Yes button to replace the original image with the newly-created image displaying the date or time.
Says "insert color cartridge," but color cartridge is inserted
some times the cartridge will not detect properly, it will happen due to either its not inserted properly or cartridge problem.best u change new another cartridge and verify it.
I got network trouble
I get that a lot your not alone :) ok if your sims card is inserted prees up and it should work.
Cartridge error
the contacts are old on the cartridge. try a new cartridge or clean the old cartridge contacts with a pencil eraser.
k24674
Grand Canyon Tech
Grand Canyon Tech
